Buzzing sound at 20 MPH - RESOLVED
Old Aug 14, 2012 | 01:32 PM
kenhlavacek's Avatar
Default Buzzing sound at 20 MPH - RESOLVED
2001 XK8 with 70K.
Just had some major AC work done (at Jag dealer) - there was a leak in a hose that they tell me was hard to get at.
Anyway, AC works fine now however, the car has developed a buzzing sound (some sort of harmonic) when driven at exactly 20MPH.
Buzzing sound goes away by the time the car reaches 23 MPH. Sounds like it's coming from the front middle.
Any thoughts?
Old Aug 15, 2012 | 07:50 AM
If the work required getting to the Heater/Evaporator Core, that involves considerable dismantling in the centre console area.
Possibly centre veneer trim panel or the centre vents loose. The veneer is bonded onto a metal backing and can set up a vibration if not firmly engaged in the securing clips
If you put a hand on these at 20MPH, does the buzz stop?
Old Aug 15, 2012 | 09:58 AM
Thanks for the thought but this is not something inside the car. It is a metallic buzzing sound coming from underneath. The best way I can describe it is if there is some sort of metal shield over the exhaust system that has not been tightened enough and vibrates (buzzes) at a certain resonance
Old Aug 15, 2012 | 11:08 AM
WhiteXKR's Avatar
Well, there a a lot of metal shields under this car.
Take it back to the dealer and have them make it right.
Old Sep 6, 2012 | 04:53 PM
Problem Resolved
Took it back to dealer - They found the left front backing plate was rubbing on the ball joint. Secured it and buzzing sound at 20 mph is gone. Cost $135.00. No parts just labor required.
Old Sep 6, 2012 | 06:01 PM
Good to hear you got it fixed and thanks for posting the solution.
I've edited the thread title to include 'RESOLVED'
yoiyoi
Dec 19, 2023 12:51 AM
RickyJay52
Sep 20, 2021 04:48 AM
JagBrian
Feb 27, 2019 07:08 PM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
XFR_Gold
Sep 2, 2015 12:24 PM
