Cam cover compatibility - crack found
Old Aug 12, 2020 | 04:26 AM
dannio636's Avatar
Default Cam cover compatibility - crack found
Hi
My 1999 xkr has a slight crack in it which causes oil to leak into a spark plug well when i fill with oil.
What cam covers are suitable as replacements, I will be going to a breakers (wreckers...) to get a suitable replacement.. Any help would be useful, then.. which gasket would go with the cam cover as certain sets go with certain covers it seems..
Thanks for the help
Old Aug 12, 2020 | 07:37 AM
michaelh's Avatar
Here's a snippet from the JEPC showing the various permutations:
My first thought was that you could probably use a cover from the AJ26 (and the part #s for the LH 'B' bank are the same above). However the cover gaskets changed after engine # 9810290000:- they got skinnier and are not a good fit in the earlier items
The AJ27 motor was also used in the X308 XJR if you can find one.
VIN 031303 was the intro of 99MY
Old Aug 12, 2020 | 08:16 AM
dannio636's Avatar
Thanks.. just puled the cover off.. i think its an early one with the spark plug hole seals joined together, plus the cover that the oil vent hole is made of plastic.. this was supposed to have been changed when i went to a 'reputable' independant jag garage to get my heads done many years ago.. christ knows what else those bodging %$Łtards have not done properly...
Old Aug 14, 2020 | 09:12 PM
jacobmstein's Avatar
Just a comment, when I pulled the cam cover on my original engine to check the tensioners there was a crack, had to grab one off a parts car to reseal it properly. Seems common.
Jnelso
Jul 10, 2020 02:52 PM
brinny
May 25, 2020 03:23 PM
max224
Jul 8, 2018 04:56 PM
jordanmc
Sep 23, 2017 03:24 PM
Car-Nut
Aug 3, 2011 03:32 PM
