Cam Cover Interchangeable?
Old Dec 11, 2024 | 08:49 AM
Zspot's Avatar
Default Cam Cover Interchangeable?
Hi everyone,
It looks like I need a new right cam cover for my 4.2 non supercharger engine. The SNG Barratt catalog shows part AJ89077, but that search produces links to screws.
I’ve heard replacement cam covers are quite expensive. My question is, since Jag used the same 4.2 engine for later models like the X150, does this mean the cam covers are interchangeable?
Seems like the continued rarity of our X100’s drives up the price of parts, so anything we can swap with a later model would good, right?
Thanks everyone!
Old Dec 11, 2024 | 08:52 AM
AbnMike's Avatar
I don't know which ones are interchangable but I found a brand new set on ebay - even had the unobtanium little rubber connecting piece that goes on the back and joins the two together for only $150.
Old Dec 11, 2024 | 09:36 AM
bladerunner919's Avatar
I suspect you may be talking about different things. I think the OP is after the actual cam cover, whereas I think you are talking about the plastic cover that just covers the engine, but is not actually functional?
Old Dec 11, 2024 | 09:44 AM
AbnMike's Avatar
Yes correct I still call mine the valve cover
Old Dec 11, 2024 | 09:58 AM
Zspot's Avatar
Correct. Also, any help sourcing the correct part number would be great. Attached are pics from the SNG catalog. I’m referencing part #21, right hand side, which looks to be part #AJ89077, which seems to be a $6 screw.
Old Dec 11, 2024 | 03:55 PM
michaelh's Avatar
Not sure where SNG got those numbers from, although these have changed a few times over the 4.2L VIN range
Here's what JEPC has to say. VIN A30645 is the intro of the 4.2L
Those part #s show a supersession route to AJ88612, which also shows it's been superseded, but Heritage shows it as the most current, although unavailable
https://parts.jaguarlandroverclassic...aft-cover.html
FWIW, the X150 4.2L shows different part #s yet again, along with a couple of supersessions.
There seems to be a crossover from the aluminium-bodied XJ up to VIN G49700.
Breaker's yard?
Old Dec 11, 2024 | 05:27 PM
Hell-Cat's Avatar
If you are replacing the cam cover due to cracking, you can effect a good repair with JB Weld. I've used Henkel-Hysol 9309 successfully on BMW plastic cam covers in the past that have stood up well to the test of time.
You don't need to use Henkel, that's just me being obsessive - JB Weld also works fine and has good longevity.
Old Dec 11, 2024 | 06:15 PM
Zspot's Avatar
Thanks Guys!
My VIN ends in A33399, so it looks like I have the first version according to your chart.
I like the JB Weld option as well. Thank you all for your insights and pointing me in the right direction.
Old Dec 12, 2024 | 09:52 AM
kstevusa's Avatar
My VIN # XXXX 50056 is a 4.2L and has some transition items that fit 2002 4.0L and then the 4.2L. also. Discovered this with order of Throttle Body gasket. Mine required the earlier, not the latter. The transition period was a strange time. The Badge on hood (bonnet) was also 4.0Lto allow depletion of stock as was the standard practice back then.
Peter_of_Australia
Dec 2, 2024 07:09 AM
Peter_of_Australia
44
Feb 4, 2024 10:42 PM
Dan219
E type ( XK-E )
Nov 27, 2023 06:45 AM
westy032001
Feb 6, 2014 09:31 PM
