Cam position sensor
Old Feb 15, 2012 | 10:00 PM
Fn2damax's Avatar
Default Cam position sensor
Does anyone have a diagram showing the position of the cam position sensor?
Old Feb 16, 2012 | 04:21 AM
joycesjag's Avatar
Fn2, welcome to the forum.
It would be helpfull if you mentioned what model, year and engine you are inquiring about. Put those details into your signature, using the "User CP" option in the top left tool bar.
Also this is an introduction section, please go to the correct model section to post any technical questions.
Enjoy all the site has to offer!
Old Feb 16, 2012 | 05:47 AM
Welcome to the forum,
Old Feb 16, 2012 | 07:09 AM
Fn2damax's Avatar
I apologize... 1999 XK8. 4.0
Old Feb 16, 2012 | 06:12 PM
MOVED
Old Feb 16, 2012 | 06:48 PM
WhiteXKR's Avatar
Welcome to the forum!
See attached. The engine transitioned right around your model. Not sure which one you have so I posted both types.
File Type: pdf
File Type: pdf
Old Feb 17, 2012 | 02:07 AM
XKRacer's Avatar
The sensor is at the end of bank 2 (L/H Drivers side), works off the inlet side so will be on the inside of the head, you cant miss it at the back, you will need to take off the fuel connector going onto the rail to remove it via a 8mm hex bolt, just slides out, if its a little tight that will be the O ring that seals it in, just give it a wiggle!
Bcrary3
Feb 21, 2023 04:29 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jaggermang
Sep 8, 2015 07:07 PM
gregster41
Sep 6, 2015 06:51 PM
