Can a 2001 xkr operate without a dash cluster
Old 11-11-2016, 03:13 PM
revauto's Avatar
Default Can a 2001 xkr operate without a dash cluster
I own a custom bodyshop and do alot fibreglass work. I want to update my own 2001 Jaguar xkr with a computerized cluster off the obd port under the dash. Does the xkr need its original cluster to run, has anyone started their xk8 or xkr without the speedo cluster?
Old 11-11-2016, 03:34 PM
fmertz's Avatar
Received 1,487 Likes on 1,043 Posts
Originally Posted by revauto
Does the xkr need its original cluster to run?
As far as I know, most definitely yes. The instrument cluster is connected to more than one data bus and hosts (one of) the bridges that allow data to flow between these busses.
This is documented in the electrical manual, "Network Configuration". It shows the "Major Instrument Cluster" as the bridge between CAN and SCP.
Old 11-11-2016, 08:14 PM
WhiteXKR's Avatar
Received 2,982 Likes on 2,123 Posts
+1. The instrument cluster is the communications hub for the vehicle and is a computer itself. Of course nothing is impossible, but it would be a very difficult job to replace it with something else.
Old 11-11-2016, 08:23 PM
grantorino62's Avatar
Nope! wont run!
Old 11-12-2016, 09:45 AM
revauto's Avatar
I noticed one plug connecting the instrument cluster, the black one, had 2 rows of 13 pins (30 total). The other plug, yellow, had the same, 2 rows of 13. Do you think if I removed the cluster and "bridge "the two plugs together, if the corresponding pins matched up, would it work?
Old 11-12-2016, 09:48 AM
WhiteXKR's Avatar
No! Do not do that! The functions on the pins are completely unrelated between the 2 connectors. Connecting them like that could cause damage across various electronic modules throughout the car and leave you with a 2 ton paperweight.
Do not mess with these systems unless you know exactly what you are doing. This means understanding what each signal does, what voltages and currents are allowable, and understanding the various vehicle networks.
Old 11-12-2016, 10:08 AM
JagV8's Avatar
Received 4,488 Likes on 3,905 Posts
You're talking about major electronics and computer work costing thousands. No-one will bother.
Old 11-12-2016, 10:46 AM
GGG is offline
Received 16,821 Likes on 12,177 Posts
...... if I removed the cluster and "bridge "the two plugs together .....
Do you seek to recreate the fabled harness smoke from Jaguars of old?
The following 2 users liked this post by GGG:
fmertz (11-12-2016), michaelh (11-12-2016)
Old 11-12-2016, 11:37 AM
dsd's Avatar
dsd
dsd is offline
As other stated, you will need the cluster. However, you can probably overlay it with a thin LCD panel and run what you want. The original cluster will be there just obscured by your custom panel.
Old 11-12-2016, 11:48 AM
revauto's Avatar
Well that answers that, I guess I wont be going that route. But I have a back-up plan to remove the instrument cluster plastic bezel, between the cluster and the wood face exterior dash. Leaving the cluster attached just not seen located behind a 13" video monitor.
Old 11-18-2016, 08:02 AM
johns55's Avatar
One thing I will mention. I have been driving my XK8 with no cluster for a few days. Seems to run fine. I have a cluster on order and waiting for delivery.
revauto (11-21-2016)
