Can anyone identify what should be plugged in here?
Old Jul 23, 2021 | 09:50 AM
Phil m's Avatar
Default Can anyone identify what should be plugged in here?
Hi All,
I new to this forum so please be gentle, I have just got my 1999 XKR Convertible and after taking the battery out to change it I noticed a "plug" that has nothing plugged in to it.
Does anyone know what should be plugged in here it is located behind the battery in the boot?
Thanks in advance.
Old Jul 23, 2021 | 10:00 AM
Johnken's Avatar
Hi Phil, this one comes up all the time. You're ok, I'm told it is a plug that was used while transporting the vehicle to the dealership.
John
Old Jul 23, 2021 | 10:19 AM
Jon89's Avatar
It kept the battery sufficiently charged during the car's ocean voyage from England to the U.S. (assuming you are indeed in the U.S.). You can simply ignore it....
Old Jul 23, 2021 | 10:21 AM
Phil m's Avatar
Phew.
Thanks very much guys.
Old Jul 23, 2021 | 10:50 AM
As above - it's for the Transit Relay.
Because this is removed at the dealership during PDI, no one ever sees it. To complete the thread, here's a drawing to illustrate how it was connected.
Jaguar use a limited number of harnesses with all required connectors so you could find other unused connectors depending on the chosen options fitted to the vehicle.
Andis28
May 27, 2021 04:21 PM
Spikepaga
Jun 16, 2020 04:43 PM
badicedog
May 18, 2019 06:11 PM
Jeff in Tucson
Oct 28, 2016 10:45 AM
matthew.r
Apr 12, 2012 05:29 AM
