Can auto headlight sensor be repaired?
Old Jul 27, 2016 | 01:17 AM
Stamford's Avatar
Default Can auto headlight sensor be repaired?
In auto-on position my headlights work intermittently. I found that knocking on the rear-view mirror causes them to go on and off. So I'm wondering if the sensor in the mirror is loose. Has anyone ever worked on the sensor. Is it possible to access it without destroying the mirror? Several times my lights have shut off and I didn't notice it right away because of the street lights. So I'm operating them manually – a minor inconvenience for sure, but one I'd like to eliminate. Thanks!
Old Jul 27, 2016 | 01:33 AM
RaceDiagnostics's Avatar
Well they can certainly be opened, but I was unable to fix the problem I had related to daylight detection. Have a look here;
https://www.jaguarforums.com/forum/x...-mirror-80568/
and
https://www.jaguarforums.com/forum/x...ll-time-79438/
Old Jul 27, 2016 | 07:28 AM
Stamford's Avatar
Thanks for the reply. My 2005 mirror looks different than the one in your thread. Its buttons are labeled comp and mirror. But if I get brave I may open it to look for a loose joint. I'm a bit afraid of letting the magic fluid run out. Is it pretty well contained?
Old Jul 27, 2016 | 09:41 AM
grantorino62's Avatar
Never took mine apart for the same issue. Got lucky, found another mirror on a 2006 wreck and swapped it. Problem solved!
Old Jul 28, 2016 | 11:30 AM
Stamford's Avatar
I wish I had a decent wrecking yard near me. Weren't you tempted to open up your broken mirror to explore?
Old Jul 28, 2016 | 11:35 AM
Jandreu's Avatar
I've opened the mirror on my 03 with no issues. First take the cover off the wiring behind the mirror and check for loose connections. You may also need to remove the console panel where the dome lights are and check for connections. If you can knock on it and it works my bet is a loose connection.
I know what you mean about getting use to the auto functions, I depend on them and am very spoiled as mine all work great!
Apr 24, 2019 04:57 AM
afterburner1
Sep 5, 2018 11:40 AM
White04X
Jun 16, 2007 09:35 PM
scchuck
Dec 3, 2006 11:39 AM
04Xtype
Oct 13, 2006 07:58 PM
