Can I borrow or buy your old laptop? (VCM + IDS 118.5)
Old May 27, 2023 | 06:54 PM
jim_63219's Avatar
Default Can I borrow or buy your old laptop? (VCM + IDS 118.5)
I'm in the business of talking to the Jag's ECU, and I've got a VCM w/ cables on the way. I also have the IDS 118.5 software installation files ready to go. I'm trying to do two things, #1: Add FOBs to my '97 XK8, and #2: Try to save a failed ECU in a 2006 XK8.
I've been advised this only works properly with a 32-bit Windows machine, and I don't have a whole lot of confidence with the units I'm seeing on Ebay. Plus for other reasons (an unrelated 1985 Buick ECM DOS program) I'm ideally trying to find one with a parallel port (for the younger folks, that's the long 25-pin fat port you find on really old computers.)
Just thought I'd throw out the request here, to either borrow or buy one that someone here may have lying around...
Old May 27, 2023 | 07:35 PM
barnter's Avatar
You might want to take a look at one of the versions available for Oracle's VM VirtualBox. Each version is an appliance that contains a clone of Windows XP 32 bit with SDD already loaded. Works fine on my Windows 10 64 bit laptop. There are videos on Youtube. For more details see https://www.jaguarforums.com/forum/g...ftware-240209/
Old May 27, 2023 | 07:54 PM
motorcarman's Avatar
The FOBs added to an X100 does NOT require WDS, or IDS.
The ignition and 'headlamp-flash' works almost ALL the time.
In case of the 1% of the time that it does not, I need WDS/IDS to 'clear all keyfob transmitters'.
Engineer1
Nov 6, 2024 02:57 PM
steve4ltr
General Tech Help
62
Feb 11, 2024 09:23 AM
onewhippedpuppy
Jun 2, 2023 09:43 PM
3oldjags
Oct 2, 2017 02:55 PM
Tombloke
Jun 7, 2017 06:34 AM
