can't move driver's seat
Old Jul 20, 2013 | 03:35 PM
TonyCanoe's Avatar
Default can't move driver's seat
Driver's seat module doesn't work, passenger side did, swapped modules, driver's side still doesn't work. Need to remove seat to change hydro hoses for convert. top. Any recommendations on how I can remove seat?
Thanks.
Old Jul 20, 2013 | 03:42 PM
jimbov8's Avatar
Have you checked the fuse for the drivers seat?
If that is ok then you are going to need very thin hands to get to the 4 hex bolts underneath.
Old Jul 20, 2013 | 04:00 PM
TonyCanoe's Avatar
Jim,Thanks. Which fuse is it? I didn't find any bad fuses on the panel behind the driver's door. My hands are not skinny so need to see if there is a better alternative!
Tony
Old Jul 20, 2013 | 04:13 PM
jimbov8's Avatar
Hi Tony,
Should be fuse No1 20A drivers side. If you checked it with a meter and it is ok then you may need a small child or a lengthened hex key.
To prove the drivers seat module, put it in the passenger side. If it doesn't work you can take the cover off. You may find the forward end tracks damaged, which is repairable.
Old Jul 20, 2013 | 04:36 PM
TonyCanoe's Avatar
Great, I'm out the door to try it now. Thanks again. Will report my findings this evening.
Tony
Old Jul 21, 2013 | 07:13 AM
TonyCanoe's Avatar
The 20A fuse in No. 1 was ok and I have power to the head rest and lumbar pump. Didn't find a break in the seat module. The seat is back most of the track so I have good access to the front two hex bolts. Will try a couple of ways to reach the back bolts.
Thanks.
Tony
Old Jul 21, 2013 | 07:32 AM
jimbov8's Avatar
If you do manage to get the seat out, check the little micro switches are all working correctly.
Old Jul 21, 2013 | 09:13 PM
TonyCanoe's Avatar
Will do as soon as I get the seat out. By then I might know how to check the micro switches too.
Thanks again.
Tony
GordoCatCar
Jan 2, 2017 01:10 PM
sadepol01
Sep 11, 2015 05:26 AM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
