car keeps going crazy and will not start - then starts
Old Sep 10, 2021 | 10:49 AM
Rabs's Avatar
Default car keeps going crazy and will not start - then starts
Hi keep having issues where car will not start it throws up so many issues - gearbox fault, dsc, etc etc
The battery is less than 2 years old and fully charged
Have a number of codes
It keeps happening and if you leave the car for a bit (each time different) it will eventually start in limp home mode. Next time you start it is not in limp home mode and just has check engine light. This then seems to clear itself also.
When I looked at u1147 on google it says that i can be related to the cat having to work over time to hide another issues and would eventually fail.....sounds expensive!!!
Old Sep 10, 2021 | 05:25 PM
Addicted2boost's Avatar
Do a hard reset on it then clear every code you can in the car. If you have a convertible, reset the driver and passenger door glass. Make sure the top is closed first before proceeding if you have a convertible. You know how to do that with the windows?
04jag
Mar 9, 2020 07:07 PM
Yaoi-Wiccan
33
Feb 3, 2020 08:39 AM
2jags1993
Nov 27, 2019 10:22 PM
SEMORGANUK
Jun 14, 2017 01:08 PM
marcel33
Apr 17, 2012 02:08 AM
