car starts then cuts out
Old Feb 26, 2013 | 02:16 PM
smoggyx100's Avatar
Default car starts then cuts out
My 1999 XK8 yesterday started doing the following:-
The engine starts then within a couple of seconds revs drop off and it cuts out.
Second or third attempt it holds a bit longer runs lumpy at 4 to 600rpm then cuts out.
However if you start it, catch it on the throttle and rev it up, its then ok and drives fine.
Im thinking sticking throttle body but any other ideas would be appreciated.
thanks
Old Feb 26, 2013 | 02:20 PM
WhiteXKR's Avatar
Check the fuel pressure while the rough start is taking place. There is a Schrader valve on the fuel rail. Cleaning the throttle body and valve cover breathers is also simple and a good idea.
Old Feb 26, 2013 | 02:25 PM
jimbov8's Avatar
Hi Smoggy,
Sounds like you may need to do bit of cleaning in the throttle body. Try it first, it costs nothing but time and could solve the problem.
Also, nice to see someone else from where i came from.
Old Feb 26, 2013 | 02:51 PM
smoggyx100's Avatar
Jimbov8 and whitexkr thanks for the info
What a coincidence your where, I would rater be with the top down - in summer.
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
msdg137
Sep 16, 2015 06:24 AM
Jaguila
Sep 5, 2015 06:16 PM
1964Daimler
Sep 2, 2015 11:41 PM
