cat won't start
Old Aug 21, 2016 | 06:39 AM
rumm5's Avatar
Default cat won't start
Hi all;
My 98 vert did not start. Bad wire to starter. Replaced. Now it cranks but doesn't try to start. I've looked at the service info, and found no other broken circuits or bad relays. What are the most likely suspects?
Old Aug 21, 2016 | 06:49 AM
jimbov8's Avatar
Bore wash, have a quick google and it will tell you what to try next.
Old Aug 21, 2016 | 08:28 AM
Gus's Avatar
Gus
See if this information helps.
Old Aug 21, 2016 | 10:51 AM
rumm5's Avatar
Thanx all;
That info will help. I wondered if the broken starter wire maybe tripped something? I don't believe its' a coincidence.
Old Aug 21, 2016 | 11:11 AM
BobRoy's Avatar
Did you check your ignition coil fuse
Old Aug 21, 2016 | 11:42 AM
Gus's Avatar
Gus
Check one thing for me. Check that the lights on the visor mirrors are working. If not check a 15a (I think) fuse in the drivers fascia door fuse box. Well check them all!!
Also When you are trying to start the car does it sound like it has compression or is it a whirling sound?
Old Aug 25, 2016 | 05:03 PM
rumm5's Avatar
Default mechanic stumped
Update;
My mechanic, good as he is, suggested taking car to dealer. It has spark but no fuel. My next question. Has anyone taken their xk to the dealer for a no start and how much did it cost you?
Old Aug 25, 2016 | 05:25 PM
brgjag's Avatar
dealer cost you just to drive it on their lot. ha ha ha
Check the fuel pump fuse?
Old Aug 25, 2016 | 05:27 PM
03 XKR's Avatar
Could the fuel cutoff switch have tripped? I think in the earlier models it was in the drivers side fascia fuse panel, in my, MY 2003, it is in the foot-well behind the plastic trim.
Old Aug 25, 2016 | 05:30 PM
Gus's Avatar
Gus
Did you check the fuse for the visor lights?
Gus
www.jagrepair.com
Old Aug 25, 2016 | 05:36 PM
Gus's Avatar
Gus
You need 3 things for the engine to start fuel, spark and compression. The lack of one will result in no start.
Meet us half way tell us what you do know..
What has your mechanic found that you have so far????
Gus
www.jagrepair.com
Old Aug 25, 2016 | 07:06 PM
RJ237's Avatar
As Gus is suggesting, do not take it to the dealer. Stay with the forum and follow directions. We can help.
Old Sep 7, 2016 | 04:04 PM
rumm5's Avatar
Default fuel pump
Hi all;
Update, took it to the dealer. Was the fuel pump. What surprised me was there was no warning. Getting car back in two days.
Old Sep 7, 2016 | 05:07 PM
Didn't your mechanic suspect that with no fuel?
Old Sep 12, 2016 | 09:03 AM
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
Think I'd contemplate switching mechanics......
mhamilton
Jun 3, 2016 09:37 AM
Darrenmb
May 31, 2016 01:40 PM
rbhines
May 27, 2016 08:42 PM
snowball
May 27, 2016 06:25 PM
jahummer
May 25, 2016 03:46 PM
