CD Changer Cartridge Stuck - new evidence points to Root Cause
Old Nov 23, 2015 | 02:03 PM
Johnken's Avatar
Default CD Changer Cartridge Stuck - new evidence points to Root Cause
Well I'm getting good at these don't do what I did posts, this time I think I learned something good though.
I have had intermittent troubles getting the Changer to spit out the cartridge, doesn't happen often but when it does it is a PIA. After reading about this I once opened her up and cleaned/relubed everthing inside. I did notice that on the rare occasion when she stuck, if I pushed down and back it would work. I did suspect the linkage was faulty.
Well the other day it happened again. I maybe got a little frustrated and pushed that little blue switch a bit too hard. It stuck in on one side! Well my next press caused the other side to stick as well. Good news: The cartridge shot right out.
Bad News: the unit reset, then ran the eject sequence, again and again - It wasn't going to stop. This switch was shorted closed in this position!
Well since this is a battery circuit, I knew it would drain the battery if I left it that way so I started my attack plans on the way home. I was happy, a nudge in the right place released the button and all is well again.
Moral: Don't push that switch too hard!! It can screw things up - a bit easier than you'd think.
Lesson Learned: This "no release issue" is clearly a switch / contact issue. I'll be soldering in a momentarty on switch shortly and never have to worry about this again.
If anyone wants me to take a photo of the solder points the switch is connected to, just ask. If we are lucky enough, they will be isolated on the board, the photo might give you a way to release from underneath if you ever needed.
derrickonline
Jun 5, 2020 08:48 PM
5adaytony
Nov 15, 2015 03:00 PM
bigcat777
Nov 8, 2015 04:06 PM
big k
Oct 27, 2015 09:09 AM
jagger
Oct 26, 2015 06:48 PM
