"CD NOT CONT" Error
Old Aug 28, 2021 | 02:20 PM
ETexJag's Avatar
Default "CD NOT CONT" Error
So the old "CD NOT CONT" reared his ugly head here in East Texas in my 2006 XKR convertible.
I saw the referral in another thread/forum to Southern Electronics, so I sent the head unit in to them.
They said the unit was un-repairable, so they sent me a replacement.
Installed the replacement, and it didn't resolve the issue.
They were also so kind as to include a new cable, which I tried (just running on the outside of the car) - still no luck.
So I played around by swapping some of the cables in the truck at the stack, and bypassed the navigation unit,
and was able to see the cd playing on the display on the head unit (but no sound),
so I thought maybe the nav unit was bad and not passing through the cd signal.
So I found a used nav unit (identical model number), but still have the same issue.
Thinking about looking for a cd changer, but I hate to keep just replacing parts, so I thought I would reach out to the forum.
Anyone have any suggestions?
TIA
Mike
Old Aug 28, 2021 | 02:52 PM
Mike,
Is your 2006 a late steel bodied X100 (1996-2006) or an early aluminium bodied X150 (2006-2014)?
Old Aug 28, 2021 | 05:30 PM
Stuart S's Avatar
He's in the wrong Forum, based on the threads he started.
We humans make misteaks.
Old Aug 29, 2021 | 11:46 AM
Johnken's Avatar
ETEX, wrong forum but you may be able to use this. I got same error message last week. I tracked it to a swinging open connection in the jack from my Bluetooth adapter to the umbilical out of the cd player. IOW in the X100 it indicates an open data connection to cd changer.
If I were you I'd go to the connection coming out of cd changer, wiggle it around see if you get lucky.
Your note about an external cable used for testing may be saying that you bypassed the cable I told you to wiggle. If so sounds like you proved it to the head unit.
John
Old Aug 30, 2021 | 07:11 AM
Stuart S's Avatar
This thread is now in the correct Forum since GGG moved it from X150 to X100.
Old Aug 30, 2021 | 08:28 AM
ETexJag's Avatar
Originally Posted by GGG
Mike,
yep - its the steel body - i'll try to keep it straight in the future.
apologies for the confusion - cheers!
Old Aug 30, 2021 | 08:34 AM
ETexJag's Avatar
John
thx for the reply, john -
i am concerned that it could be a wiring harness issue somewhere in the system,
but i'll probably just look for a used cd changer -
meanwhile, i'll just get out some old cassettes -
cheers!
ablack
Jul 26, 2019 11:48 PM
Jon Frey
Jan 23, 2019 11:54 AM
dmpsqrd
Audio/Visual Electronics
Jul 9, 2016 01:43 AM
greenforest56
Jan 27, 2015 05:49 PM
H20boy
Oct 18, 2012 10:44 PM
