Center 3 gauge cluster dimensions? Thanks
Old Aug 20, 2023 | 10:57 AM
Shoreguy's Avatar
Veteran: Air Force
Default Center 3 gauge cluster dimensions? Thanks
Happy summer everyone! It's been hot but at least you don't have to shovel it, so there's that. Guys I'm working on a panel to convert a nav center dash panel to a 3 gauge panel. I'm just in the mock up stage trying to see if my design will work. The three dimensions ABC is all I need to finish. As always my friends thank you in advance and hope you're all doing well.
Cheers!
Andrew
Old Aug 20, 2023 | 11:58 AM
Jag#4's Avatar
Here's my attempt to get the measurements. All are in inches. "D" is top to bottom of panel.
Hope this helps.
Old Aug 20, 2023 | 12:05 PM
Terrific's Avatar
My 97 has factory gauges. Holes are actually indented and gauges have chrome rims. Dimension A is approx. 8 5/8 ln. distance between gauges is 1/2 lnch and dia of gauges is 2 5/8 inch. with rim. sorry I don't have a photo available. I did post a photo when I posted my cup holder fabrication. You could probably see it if you know how to look up my posts.
Old Aug 21, 2023 | 12:42 AM
Pistnbroke's Avatar
Are you proposing to fit Jag gauges to this ? If you are remember they are all fake gauges so are inaccurate
frank wood
Jul 7, 2022 08:14 AM
Shoreguy
Nov 27, 2020 09:53 AM
Forcedair1
Jun 17, 2020 09:14 AM
Burnham
Nov 15, 2015 10:35 PM
Robert
XJ40 ( XJ81 )
Aug 4, 2011 08:30 PM
