Changing Front Engine Mounts
Old May 7, 2025 | 10:02 AM
daro31's Avatar
Default Changing Front Engine Mounts
Are there any instructions for changing front motor mounts? 2000 XK8 Convertible.
My buddies 2000 XK8 needs the front engine mounts changed, one is leaking the other is collapsed and dry as a bone.
I have found several right ups on changing the rear mounts but nothing for the front. They look fairly straight forward but I always like to check ahead for and suggestions that you experts can suggest.
Old May 7, 2025 | 10:43 AM
bladerunner919's Avatar
Easy - support the engine, undo the bolts, lift engine a bit, swap mounts, lower engine, install bolts.
Old May 7, 2025 | 11:46 AM
giandanielxk8's Avatar
Those are not the engine mounts, those are the front subframe mounts. It's significantly more complicated. You will have to drop the subframe. And those don't contain fluid. What you're seeing is a motor oil leak, possibly from the timing cover or the harmonic balancer seal.
Old May 7, 2025 | 05:48 PM
baxtor's Avatar
As Gian stated, front crossmember bushes.
l replaced mine several years ago, with crossmember in place, it can be done but would consider dropping the front end if doing the job again. they originally had a plastic body which makes it possible to "dig" them out with sharp chisel.
​#2 in pic. Part # MJA2370AJ
Old May 7, 2025 | 07:30 PM
Hell-Cat's Avatar
290 pounds sterling each ??? That is insane, though that does include VAT....
Even Lamborghini charge less than 80 pounds for their equivalent part.
Small wonder that Jaguar went down the pan.
Old May 7, 2025 | 08:39 PM
Yeah, the upcharge is insane for what is essentially a bush. I bought them from SNG Barratt, but don't remember paying anywhere near that amount. I don't think I went with the OE because of the price. I haven't had a problem with them in the past 3 years since I replaced them.
Old May 8, 2025 | 07:14 AM
michaelh's Avatar
I've no idea what is going on with Heritage. I have the receipt here for the ones I bought from the local dealership (albeit April 2022) which amounts to £90.13 / $120.41) for the two.
Old May 8, 2025 | 08:53 AM
daro31's Avatar
Thank you for the information it is significantly better to find that out.
Old May 8, 2025 | 09:15 AM
Hell-Cat's Avatar
SNG Barrett USA are listing that part at $407 each (or $55 for a MaitaiHoPong after market part) , I'll schedule a kidney broker appointment before I do that job.
Old May 8, 2025 | 01:23 PM
wymjym's Avatar
ÜRO PARTS MNC7500AB
$72 usd @ at Rock Auto
wj
Old May 8, 2025 | 04:13 PM
robak's Avatar
hey guys. i know we get them from a good aftermarket company. i changed mine as the frame was out and i thinkni took „meyle“. i can look that up if you need the brand.
only for the engine mounts i had to stick with uro…
Old May 8, 2025 | 04:20 PM
baxtor's Avatar
Originally Posted by wymjym
ÜRO PARTS MNC7500AB
wj
But the engine mount is not the part he actually needs.
Old May 10, 2025 | 09:09 AM
wymjym's Avatar
I missed that point, need to read closer.
wj
Ledmi
May 5, 2025 03:56 PM
Flex320
XJ XJ12 ( X305 )
Feb 9, 2023 02:18 AM
Flex320
XJ XJ12 ( X305 )
Jan 5, 2023 12:12 PM
Britrover
Mar 10, 2016 10:49 PM
62sunbeam
Feb 14, 2013 08:25 PM
