changing transmission fluid (XKR)
Old Aug 27, 2018 | 02:19 PM
zray's Avatar
Default changing transmission fluid (XKR)
on an '02 XKR,
to just change the fluid, is disconnecting the lines into the transmission cooler the easiest way to proceed ? Direct one line into the used fluid receptacle receptacle and on the other line, have a hose going into the clean new fluid container with the other end connected to the intake transmission line ? Bad idea ?
am wanting to put off doing a complete transmission service at this time.
is there a consensus on best synthetic ATF ?
Z.
Old Aug 27, 2018 | 08:18 PM
AZjag1999's Avatar
Originally Posted by zray
on an '02 XKR,
Z.
Shell ATF 134 will work just fine. This link may be helpful, in that it gives you different vendors to look at: https://bevo.mercedes-benz.com/bevol..._en.html#close
Can't speak for the fluid flush. I just did a simple drain and refill 2 times, and the fluid in mine looks fine.
nasa25
Sep 7, 2014 08:09 AM
TinyDancer91991
Aug 28, 2013 05:39 AM
mattrains
Jun 26, 2013 05:15 PM
wordman
Feb 5, 2013 07:23 AM
fasterthebetter
Jul 14, 2012 11:34 PM
