Check Engine Light code P0455
Old Dec 12, 2007 | 08:17 PM
jhe2003's Avatar
Default RE: Check Engine Light code P0455
If you have the dual charcoal canisters, there is this small hose about 2.5 inches long that goes from the passenger side canister to the canister close valve that develops a crack over time. I would check this first, should be easy to see if you get under there with a flash light from thepass. side rear.Its a common problem with earlier Xk's and since its a "GROSS" leak should be easy to see.
Old Dec 13, 2007 | 08:25 PM
Sounds like good info jhe!
Nice one
Let us know how you go firstjag
Jim
Old Jan 6, 2008 | 05:31 PM
FactoryJaguarTech's Avatar
If you have P0455 and no leak present I would suspect faulty purge valve. This is located in the left front fender well of vehicle. Do you smell fuel? Does vehicle idle well?
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
