Chrome One-Piece Lug Nut Sources....
Old Oct 15, 2012 | 12:49 PM
Jon89's Avatar
Default Chrome One-Piece Lug Nut Sources....
I replaced the crappy factory capped acorn-style lug nuts on our S-Type with solid one-piece lug nuts not quite three years ago. I'd like to do the same for our XK8 factory capped acorn-style lug nuts. They are not as crappy as the S-Type factory lug nuts were, but I despise all capped acorn-style lug nuts....
Has anyone found a reasonably-priced supplier who offers a good solid one-piece lug nut that will not pit or rust? I want to stay with 23mm lug nut heads so I will not have to change my factory trunk lug wrench as well....
Old Oct 15, 2012 | 02:42 PM
user 2029223's Avatar
Banned
Jon
Here is an odd bit of info that may help. On my old 05 XJR you could use a Mitsubishi Outlander Lug Nut # 455707 @ $4.80 as of Mch 20010.
Check it out for your car.
Old Oct 15, 2012 | 09:28 PM
XKRacer's Avatar
Take a look HERE
I think you will find the Mitusbishi items will be metric and the XK are UNF
Old Oct 16, 2012 | 06:18 AM
Banned
I don't know what to tell you. I certainly don't want to put out a bum steer and I can't attest to the tech specs of the nuts/ bolts. All I really know is that a local Jag enthusiast here in FL swears by the info.
A visit to Jon's local Mitsubishi dealer with a saw buck is a cheep way to sort it out says I.
Old Oct 16, 2012 | 08:02 AM
XKRacer's Avatar
Sorry I did not make myself clear enough, I am pretty sure the XJs are metric threads 12 x 1.5 but XKs are UNF so the mitsubishi nuts will not fit
Old Oct 16, 2012 | 08:52 AM
Jon89's Avatar
Thanks for the feedback, guys. I have Mitsubishi solid lug nuts (designed for the Chrysler Sebring) on our S-Type and they've done quite well in nearly three years of usage. But they are metric and the if the XK8 requires UNF, I doubt if Mitsubishi makes any for this application....
Can someone confirm the XK8 lug nut specs?
Old Oct 16, 2012 | 09:22 AM
XKRacer's Avatar
Take my word for it they are 1/2" UNF
Old Oct 16, 2012 | 09:40 AM
Jon89's Avatar
Just got off the phone with our local Jaguar dealership parts department. They say my wife's 2006 XK8 takes a 12 x 1.25 lug nut with a 23mm head. Are you saying they are incorrect?
Old Oct 16, 2012 | 09:45 AM
XKRacer's Avatar
Yes I am all XK8s are UNF only the 2006 XK (X150) is 12mm
Old Oct 16, 2012 | 09:59 AM
Jon89's Avatar
Is it not possible that the UK cars were fitted with UNF while the US cars were indeed fitted with 12 x 1.25? Just looking for absolute clarification before I proceed....
Old Oct 16, 2012 | 10:08 AM
WhiteXKR's Avatar
Jon, bring a lug nut to an Advanced Auto Parts store. Most of the stores have a lug nut fitting gauge. I am pretty sure you will find that the XK8 lug nut does not fit any of the threads on the gauge (since they do not sell 1/2" UNF lugnuts).
Old Oct 16, 2012 | 11:43 AM
Jon89's Avatar
So the million-dollar (or euro) question apparently is: Who sells UNF 1/2" solid lug nuts in the US for what I would consider to be a reasonble price (no more than $100 for 20 lug nuts)?
Old Oct 16, 2012 | 02:35 PM
MRomanik's Avatar
Veteran: Air Force
Jon,
When I needed lug nuts for my XK8 I could not find any in the US. I ended up getting them from Adamesh in the UK. They are not chrome. If I remember right it was less than $100.
Old Oct 16, 2012 | 07:00 PM
ccfulton's Avatar
I may show my ignorance by asking this, but since the OEM wheels are hub centric, what would be the harm in using a tapered nut?
Dumb questions aside, what about something like:
Flat Chrome Lug Nuts 1/2-20 - 8 pcs
or
Summit Racing SUM-7540083 - Summit Racing® Lug Nuts - Overview - SummitRacing.com
Old Oct 16, 2012 | 07:16 PM
I did some research on this today, it seems not surprisingly that Tony is correct the change to Metric was with the new models (X150) in 2006.
Adamesh,was was the source I came up with too and they are cheap as chips!
Replacement Wheel Nuts - Early Models
Old Oct 16, 2012 | 07:28 PM
plums's Avatar
The shanks look awfully short on the Adamesh supplied lug nuts. Anyone know the dimensions on the shank? (diameter & length)
Old Oct 16, 2012 | 07:31 PM
oldjaglover's Avatar
Yeah....more info. I'd love to replace my clickers.
Old Oct 16, 2012 | 08:02 PM
I couldn't find dimensions anywhere, maybe someone can take one off and check?
Adamesh also has a pic of Jaguar nuts which are very short also.
Old Oct 16, 2012 | 11:12 PM
H20boy's Avatar
I did a thread on replacements, even measured them...what a nightmare. https://www.jaguarforums.com/forum/x...acement-36542/
Old Oct 17, 2012 | 12:30 AM
plums's Avatar
Here are the measurements as found on the factory lugnuts used on asteroids:
LUGNUTS
1/2 x 20
shank diameter 0.7025"
shank depth 0.4230"
washer thickness 0.1285"
