Cigarette lighter fuse keeps blowing
The 15a fuse for the outlet keeps blowing. I only use this for cell charger adaptors and I'm using one that hasnt given any problem in my other car so I dont believe its the charger. I'm wondering if increasing to a 20 amp fuse presents any risk to car or electronics I'm charging?
Never increase the rated fuse on a given circuit, it's there for a reason. Either the circuit is being overloaded or there is a short.
Time to do a bit of investigation. If you can read a circuit diagram download yours free at jagrepair.com.
Just had a look at the diagram and it appears you should have a 20A fuse fitted and not a 15A fuse.
Fuse 14 passenger side fuse box.
That said, it would still be prudent to find out why a 15A fuse is rupturing on a phone charger.
In my experience if you can wiggle the charger in the socket, its too loose and can cause a spark as inserted or removed. Causing a spark can pop a fuse especially if its 5 amps under spec. NEVER install a higher amp fuse beyond the circuit's rating.
The fuse to my cigarette lighter kept blowing and it turned out to be a pinched wire under the shifter. I found it after taking the center console out to run wires for an antenna up/down switch.
billysiv
Sep 13, 2016 08:11 AM
jerry_hoback
Sep 12, 2016 08:12 PM
