Click when opening/closing passenger door
Old Apr 30, 2025 | 12:20 PM
MVMonarch's Avatar
Default Click when opening/closing passenger door
Consistent “click” sound when opening and closing passenger door. Both hinges are fine and operate freely. Seems to be coming from door limit lever that passes into the center edge of the door frame. Ideas?
Old Apr 30, 2025 | 02:08 PM
Jon89's Avatar
Hit it with a couple shots of white lithium grease spray....
Old Apr 30, 2025 | 06:27 PM
MVMonarch's Avatar
Slight movement of the mount where the end of the door limit rod pivots was the culprit. Tightened the 10mm bolt that is not visible behind the pivot point. Lubricated moving parts and called it a day!
Old May 1, 2025 | 03:22 PM
twinsemi's Avatar
Darn. I would have guessed the window mechanism.
ddanielcigars
Jun 27, 2024 05:31 PM
FastCat85
Nov 13, 2021 09:16 PM
Redlemon
F-Pace (X761) / C-X17
Nov 11, 2021 08:03 AM
jima
Sep 13, 2019 10:27 AM
StevenUSAnh
Nov 27, 2016 09:49 AM
