code coming up
Old Oct 31, 2016 | 08:46 AM
tony bosco's Avatar
Cool code coming up
code coming up says restricted performance.....................any ideas as to what this means ?? comes and goes ??? also had an engine chech light come on.... a'm gona clear it now >>>>.... tony
Old Oct 31, 2016 | 09:06 AM
Don't clear it before finding out what the actual code is.
Old Oct 31, 2016 | 09:30 AM
tony bosco's Avatar
code came up 327 then 327 with an arrow next to it or some kind of marking
and code 1000 with the same markings of an arrow......... code 1000 was not in my book..... it only went up to po 998 code 327 says knock sensor 1circut low input bank 1 or 1 sensor..... tony
Old Oct 31, 2016 | 09:36 AM
Gus's Avatar
Gus
This link is for your car and will give you an accurate description of your fault codes.
Link http://jagrepair.com/images/AutoRepa..._2001_OBD2.pdf
As for the knock sensor have you washed your engine recently? If so know that water and knock sensor are not compatible.
Old Oct 31, 2016 | 09:43 AM
P1000 means you have a problem it will change to P1111 when everything is good.
As you say P0327 is the knock sensor, it could be a bad connection or wire or the sensor itself.
Old Oct 31, 2016 | 11:34 AM
tony bosco's Avatar
I found a part number for the 327 knock sensor..... it's LNE 1692 AA $ 109 from SNG.... gona see if any other codes pop up before I order....Does this sound like the right one ?
Old Oct 31, 2016 | 12:23 PM
tony bosco's Avatar
Cool
just checked again and afew 1642,43,44 46 codes came up ....I reset again and all went away ??? no 1600's in my book either... rite now alls clear do you think I should purchase the knock sensor (LNE 1692 AA ) or wait to see what happens ????? tony
Old Oct 31, 2016 | 12:32 PM
Mikey's Avatar
I think you should stop deleting codes. Use them to find out what your car is telling you.
Old Oct 31, 2016 | 12:58 PM
tony bosco's Avatar
Cool
your right.... but these high numbers are not in my book of codes..... maybe i'll run it for another lil while and see what happens to be sure....
Old Oct 31, 2016 | 01:35 PM
Mikey's Avatar
Throw away your book and use the one Gus kindly posted above.
Old Oct 31, 2016 | 02:37 PM
RJ237's Avatar
Also be sure your battery is fully charged, also get it load tested. A weak battery can cause a lot of strange codes.
Old Oct 31, 2016 | 02:54 PM
Gus's Avatar
Gus
Tell me why people do not read my posts and use my links? I just want to reach out and touch someone.....
I am trying to help!!
Gus
www.jagrepair.com
Old Oct 31, 2016 | 04:55 PM
Dale Dunn's Avatar
I read them Gus and they have helped me tremendously!!!
Old Nov 1, 2016 | 06:22 AM
tony bosco's Avatar
can't find my new post.... anyway...... checking out your codes GUS and the battery is also brand new... maybe 6 months or so.... tks again................ T.
