Coil cover question
Old Jun 26, 2009 | 03:19 PM
SeismicGuy's Avatar
Default Coil cover question
I am aware that there were 2 types of coil covers used on the XK8/XKR. There is the first type that is attached to the cam covers via several screws, and there is the later type that is an overall larger plastic cover that press-fits to metal studs that extend up from the cam covers. In my 2005 XKR, I obviously have the latter style and I consider this to be a fragile and inferior design.
I assume that the plastic pegs that accept the metal studs will get brittle and break over time. In a parts list that I was able to obtain, it looks like the old style coil covers can be ordered apart from the cam covers, but I could not find a part number for the new style covers. Can these be ordered independently of the cam covers? I am just asking in anticipation of these eventually breaking.
Thanks,
Doug
Old Jul 5, 2009 | 09:51 PM
GordoCatCar's Avatar
On the first version coil covers, the knurled metal nuts embedded into the cam covers will easily strip out; so I am not so certain they are a 'better' option. Considering Jag changed from these to the later version suggests they aren't. On my '97, a few of these stripped, which required they be reinserted and bonded with some JB Weld. So far the fix has held. gordo
cissdm
May 3, 2016 06:02 AM
Dicque
Sep 19, 2015 12:53 PM
jfitzoz
Sep 7, 2015 04:28 AM
philwarner
Sep 6, 2015 11:10 PM
lordpeterk
Sep 6, 2015 01:50 PM
