Coincidence or just bad luck P0105 code
Old May 24, 2020 | 06:02 PM
YYC guy's Avatar
Default Coincidence or just bad luck P0105 code
Hi All, Hope everyone is safe and well.
I just had both passenger side O2 sensors replaced due to a P1646 code by my local indie Jag specialist.
I haven’t driven the car since the repairs, I took it out for spin yesterday and the MIL light came on. I checked the codes and it showed P0105 manifold absolute pressure barro circuit.
Is this just a coincidence or could something be knocked off or damaged during the O2 work?
Old May 24, 2020 | 08:10 PM
avern1's Avatar
It's possible that the connector or wiring has been disturbed. It is located towards the bottom of the throttle body elbow on the left side. Take a look, check the connector is tight and push in on the wires in case a tab is loose.
Old May 25, 2020 | 02:51 AM
My copy of Jaguar DTC lookup for P0105 shows MAP error:
BARO circuit faults are P0106, P0107 and P0108.
Old May 26, 2020 | 09:51 AM
YYC guy's Avatar
Hi Guys,
I checked the MAP sensor and the vacuum tube has fallen or been knocked off. Quick 10 second job for a change!
Thanks to Avern1 and GGG for their Help.
guy
Jan 28, 2026 03:06 PM
OldMike
Oct 3, 2016 10:02 AM
MARK
Jan 29, 2012 09:54 AM
jkjag
Sep 27, 2011 12:03 PM
Tracy
Jul 13, 2009 11:47 PM
