common problems
You might want to ask this question in the correct forum, which is located here:
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
The MOST COMMON PROBLEM is not reading the FAQ's before posting this question.
https://www.jaguarforums.com/forum/x...ts-data-29800/
To summarise:
1. tensioners (early plastic)
2. cooling system (plastic components/lots of rubber hoses)
3. so called "sealed for life" transmission (fluid and filter changes increase unit life)
Electrical/electronic module issues are rising as the vehicles age.
To summarise:
