condensation in headlight
hello forum, cars back from bodyshop... did a good job..... question... i have some condensation build up in my headlight any way to get rid of it... looks like it rained in there.....................
It's a common problem. Lots of threads on this if you search the forum.
Here's one of many: https://www.jaguarforums.com/forum/x...oisture-28698/
thanks jag#4 will check it out ... lot of moisture on the passenger side.........looks alot better when both headlights are nice and clear... had work done on car , after they detailed it , it came back with all this moisture ? thanks again tony
As Mike says, condensation on the inside of the glass is a regular issue. It can be minimised but there is no complete solution to the problem.
From your description, it sounds like it could be more than that condensation and the bodyshop may have been over zealous with their final cleaning? If so and there is water inside the headlight(s), be careful how you dry it. The silver coating inside the headlight shells is easily damaged and flakes off.
Fletch44
Sep 28, 2015 02:21 PM
