condensation in headlight
Old Jun 27, 2014 | 07:06 PM
tony bosco's Avatar
Cool condensation in headlight
hello forum, cars back from bodyshop... did a good job..... question... i have some condensation build up in my headlight any way to get rid of it... looks like it rained in there.....................
Old Jun 27, 2014 | 08:44 PM
Jag#4's Avatar
It's a common problem. Lots of threads on this if you search the forum.
Here's one of many: https://www.jaguarforums.com/forum/x...oisture-28698/
Old Jun 28, 2014 | 02:36 AM
tony bosco's Avatar
Cool condensation lights
thanks jag#4 will check it out ... lot of moisture on the passenger side.........looks alot better when both headlights are nice and clear... had work done on car , after they detailed it , it came back with all this moisture ? thanks again tony
Old Jun 28, 2014 | 03:19 AM
As Mike says, condensation on the inside of the glass is a regular issue. It can be minimised but there is no complete solution to the problem.
From your description, it sounds like it could be more than that condensation and the bodyshop may have been over zealous with their final cleaning? If so and there is water inside the headlight(s), be careful how you dry it. The silver coating inside the headlight shells is easily damaged and flakes off.
Old Jun 28, 2014 | 02:50 PM
keestanis's Avatar
I just open the plastic lid on top of the light unit, put a hairdryer in it for abt 10 mins and problem's gone; Just fresh air will do
Old Jul 1, 2014 | 10:52 AM
tony bosco's Avatar
Cool condensation in lights
left the plastic cover under the hood open and it seemed to do the trick.... so far the moisture is gone............ thanks again everybody..tony
Old Jul 1, 2014 | 10:56 AM
jimbov8's Avatar
Just remember Tony, that without the cover you could get all sorts of crap in there.
Worth keeping an eye on it.
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
