Convertible top
Old Apr 29, 2016 | 07:51 PM
Ksnowcut's Avatar
Question Convertible top
Need some help ,I press the button to put the top down and does nothing .windows don't do anything . Sounds like a clicking sound coming from boot when I press the button . Can anyone lead me in the right direction. Should the resevior be full or up the the 2 line on the side . Thanks Ksnowcut
Old Apr 30, 2016 | 08:56 AM
WhiteXKR's Avatar
The fluid should be between the two lines on the side of the reservoir. Make sure the petcock on the pump is turned fully clockwise.
If you still have trouble post again.
If you still have the original fluid, it may need to be flushed...the old fluids tend to gel.
Old Apr 30, 2016 | 09:42 AM
RJ237's Avatar
It would help if we knew what year car. You can add this to your signature if you open the USER CP in the black bar at the top of the page.
If the fluid is green it's Pentosin CHF 11S, which is correct. If yellow, the system must be flushed with Pentosin.
Old Apr 30, 2016 | 11:14 AM
Jandreu's Avatar
OP says a clicking sound from the boot when the button is pressed, may be a bad relay. In the boot just rear of the battery there's a fuse/relay box, all the relays are the same type, try moving them around.
jobagadonuts
Apr 30, 2016 11:13 PM
brinny
Apr 27, 2016 02:07 PM
Traindriver69
Apr 26, 2016 07:23 AM
psb1013
Apr 25, 2016 10:32 AM
SinF
Apr 25, 2016 09:08 AM
