convertible top fluid
Old Aug 14, 2009 | 01:39 AM
lcyoung's Avatar
Default convertible top fluid
i got a 2002 jaguar xkr. in my fluid in the convertible top is real low in the pump.. im trying to find out. what kind of fluid can i put in there. and how do i put the fluid in the pump.. please tell me i dont have to go to the dealer..... thanks
Old Aug 14, 2009 | 05:59 AM
test point's Avatar
The top hydraulic system requires Pentosin CHF 11s fluid. It is available at NAPA stores for less than $20 per liter.
You have a leak that should be repaired if you have lost fluid. Most likely is the top latch. Any signs of green fluid inside the top console? The other high leak areas are the tops of the hydraulic cylinders. Look under the car for wet areas in front of the rear wheels.
There is a small brass cap at the top of the reservoir. It is really not visible but you can feel it and remove with a wrench. You will need a special tool to add fluid. Something along the order of a turkey baster with a piece of hardware store tubing attached.
Old Aug 14, 2009 | 01:27 PM
lcyoung's Avatar
test point i found the fluid at vw dealership.. i went to put the fluid in the reservoir.. in one of the hydraulic lines on the back if the pump had come off.. what couldve cause this too happen
Old Aug 14, 2009 | 01:50 PM
test point's Avatar
Not tightened to specs to begin with.
Old Aug 14, 2009 | 01:58 PM
lcyoung's Avatar
everytime i put it on it pop right back off.. n how much hydraulic fluid should b in the reservoir
Old Aug 14, 2009 | 02:18 PM
lcyoung's Avatar
mechanic said im gonna need them lines
Old Aug 14, 2009 | 02:31 PM
Gus's Avatar
Gus
Go to my page and look at the info I have on the roof hoses
FrickenJag
Jun 16, 2025 02:15 PM
1100me
Jul 24, 2023 06:10 PM
Rivguy
Dec 4, 2020 07:55 AM
sogood
Sep 15, 2015 07:35 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
