convertible top hose repair kit
Old Nov 27, 2015 | 06:49 PM
alanroberts50's Avatar
Default convertible top hose repair kit
Hi looking for feedback, especially the years 2000 to 2003 which I think had worse hoses than the earlier models. I just had the top lock hoses replaced with the dealer supplied repair kit and my mechanic really did not want to do it and I understand why. The dealer was reluctant to sell the kit and the mechanic said don't use the top unless you have to before selling the car!
I would appreciate hearing from anyone that's had this repair done and how long ago. Also I would like to hear from anyone that had it done and then had issues like other parts of the system leaking fluid due to the increased strain on the older hoses.
Thanks in advance,
Alan
Old Nov 27, 2015 | 07:02 PM
WhiteXKR's Avatar
The repair kit will fail at the splice in fairly short order because the hoses are degraded. It could be immediate to probably a few months. That is why it has been discontinued. A proper repair involves replacing the faulty hoses.
Old Nov 27, 2015 | 07:04 PM
test point's Avatar
The hose splice kit was supplied by Jaguar to reduce the huge expense of replacing hundreds, if not thousands of failed hoses under warranty.
It did not work.
The splice reliability failed leading to complete hose replacement after the expense of the splice.
The splice kits were withdrawn and disappeared into history. If you are knowingly buying into a car with a splice kit installed be prepared to replace the entire hoses at some near term point.
I actually repaired the hoses with the repair kit in my '00 XK8 but 'fortunately' the car was totaled by a guy in a 25 year old Jeep before it failed again.
Old Nov 27, 2015 | 08:01 PM
Gus's Avatar
Gus
This link should give you the information you need. As for the hose repair kit it does not work.
convincor
Nov 30, 2015 06:52 AM
max224
Nov 28, 2015 07:57 AM
jagski2
Nov 22, 2015 05:11 PM
XXCalibar
Nov 17, 2015 12:03 PM
Inspector
Nov 13, 2015 01:44 PM
