Convertible top not latched
Old Sep 28, 2017 | 04:19 PM
hamracing's Avatar
Default Convertible top not latched
Closed my hood (roof) last night and it closed latched and rear windows went up. I then noticed the HOOD NOT LATCHED warning on the dash. Thinking it just needed re closing I attempted to re open the hood. BAD MOVE! The rear windows went down and then stopped. Top didn't come down or un latch . I am now left with my rear windows down and a hood that wont open. Any idea how to resolve problem. Have made sure top is locked by checking with the allen key and it is fully closed but the message is still showing on the dash. so I think it is the switch on the top lock. The problem is I cant get the hood open to get to the switch. I have released the pressure at the pump but there is a lot of resistance when I try to open the hood manually. Any help welcomed
Old Sep 28, 2017 | 04:45 PM
avern1's Avatar
If you have the cars handbook you can follow the manual opening/closing procedure. If not the go to the boot/trunk and open the tee shaped petcock on the pump. Then unlatch the roof/hood and manually put it at full open position. Then try spraying some WD-40 on the latch to free up the limit switches.
Close the petcock, move the latch to closed and then try to close the roof with the button. The latch should pop up and the roof should begin to rise.
By the way while you are there check the pump level.
Old Sep 28, 2017 | 04:46 PM
avern1's Avatar
edited to delete duplicate of post
Old Sep 29, 2017 | 03:43 AM
hamracing's Avatar
Thanks for reply. I have checked the hand book and it says CAUTION NO NOT ATTEMPT TO OPEN CONVERTIBLT TOP MANUALLY AS DAMAGE TO THE LINKAGE MECHANISUM MAY OCCUR. Can anyone advise me the correct way to open without causing any damage.
Old Sep 29, 2017 | 04:12 AM
here is a link to manual operations procedures
JagRepair.com - Jaguar Repair Information Resource
