coolant at 201 and no fans
Old Jun 24, 2022 | 04:01 PM
stevepaa's Avatar
Default coolant at 201 and no fans
What can I check?
If I disconnect temp connector will that force fans on?
Old Jun 24, 2022 | 04:32 PM
zray's Avatar
Do these charts help ?
turning on the a/c should turn them on.
Z
Old Jun 24, 2022 | 05:25 PM
stevepaa's Avatar
I will need to recharge the AC then.
Old Jun 24, 2022 | 06:07 PM
baxtor's Avatar
Originally Posted by stevepaa
What can I check?
No. You can jump at the temp sensor plug with resistor shown which will turn them on. A/C being on is a hassle and not definitive because of pressure switch involvement,
Old Jun 24, 2022 | 11:53 PM
stevepaa's Avatar
if i read that correctly 100 ohm 5% 1 watt resistor ?
what is range of resistance that willwork
Old Jun 25, 2022 | 12:47 AM
baxtor's Avatar
Sorry but that's a question l can't answer. Just know it will mimic fan on signal. Unplug at temp sensor insert resistor into plug, ignition on, fan runs, if not something is wrong.
Old Jun 25, 2022 | 01:24 AM
Pistnbroke's Avatar
I have my fans running at half speed all the time ..you just earth one wire . Works as normal running a little after the engine is shut off and aircon/high speed as normal ..engine at 88C ( 190F ) just rising slighty if you put your pedal to the metal . Measured on scangauge.
If you do a search I wrote it up ..will try to find it for you.
You are in luck.
Running temperature / Thermostat / Fans - Jaguar Forums - Jaguar Enthusiasts Forum
Now been in use for many miles and no problem.
Old Jun 26, 2022 | 04:35 PM
stevepaa's Avatar
I recharged ac and everything is okay.
bocatrip
Sep 24, 2021 03:48 PM
Alex Martinez
19
Feb 28, 2018 02:14 PM
Cadillac
XJ40 ( XJ81 )
Jul 2, 2010 12:57 PM
Chas944
Apr 17, 2010 02:49 PM
