Coolant expansion tank cap
New member here and new owner of a gorgeous XK8.
Checking the coolant level today in the expansion tank (OK) and the pressure cap came apart in several pieces. Put it back together and reinstalled, but suspect this is not normal. Ordered a new replacement cap. Am I on the right track?
Jack
normal level is 100% full when the engine is cold..
note: the expansion tank cap seals with 2 O-rings. Just put it on snug If you tighten it really tight it won’t last long.
the o-rings seal just fine without much cap tightening. I learned that on this forum.
Z
Z
As @kstevusa mentioned, always back the cap off a little. It will last a lot longer that way
Z
Z
Richard
Hello “leave-no-stone-unturned” Richard,
early onset Alzheimer’s is a good possibility.
Z
Z
Best,
Rick
Motorman,
I'm sorry I didn't properly identify you as the source of the quote that I also mangled in the post, above. I've benefitted from your knowledge and experience often and sincerely apologize. My problem is that I don't know how to edit my posts without losing them and starting over. Maybe I need to write them out before I start entering them on my phone.
Best,
Rick
Best,
Rick
weltidave
Nov 20, 2021 04:16 PM
