coolant leak and no power to door mirrors.
Old Sep 20, 2022 | 01:14 PM
Ant Buck's Avatar
Default coolant leak and no power to door mirrors.
Two issues to address today. First on the list is a coolant leak coming from the rear of the engine, as when i look under the car i can see coolant on the exhaust. My question is to you learned people is where the most likely place it is leaking. Secondly, i seem to have lost power to the folding mirrors, not sure if this could be down to the switch as i only get up movement on either mirror on the switch. I stripped the switch down when i first bought the car and cleaned the crud off the circuit board (damp had got in and the copper or brass contacts had turned green)it made no difference to the operation as i think the board is damaged from the damp, but saying that the power fold function still worked. I will replace the switch but i don't think this is the folding issue. Any advice on these issues will be much appreciated. Many thanks. Anthony.
Ltd
Apr 20, 2019 09:23 PM
Marqymarquis
Sep 27, 2018 01:12 PM
strawinski
Jan 9, 2015 05:40 PM
Grant Francis
Oct 7, 2012 09:47 AM
bper
Jul 9, 2010 03:49 AM
