coolant level sensor
tomorrow i'm going to try to fix the sensor... but first i just noticed a hose missing from the top of the reserve is one suppose to be with out a hose, or maby that's the problem ? what do you think.
well, changed the sensor was pretty easy but coolant light only went out for 5 minuets. took out again and cleaned inside where sensor goes with solution and a q-tip still no luck. i think i'll have to just replace the whole unit. will have to order one first. also fixed my emergency brake light, cables under car needed tightening up also adjusted emergency brakes on both rear wheels. cruise started working also. ( don't know how ?) put new rear brakes in too. had some help , thank god...................
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
