coolant tank
Old May 26, 2014 | 07:29 AM
tony bosco's Avatar
Cool coolant tank
need to replace the expansion coolant tank on a 2001 xk8 any ideas on where i can purchase a tank at a good price. already changed sensor. should i try the cap next or just go for the tank.? thanks tony
Old May 26, 2014 | 08:08 AM
Jag#4's Avatar
In the long run, I'd advise changing the tank. Unless otherwise noted, they come with the cap and sensor, so you're all set.
These are known problem areas, so bite the bullet and get the full tank setup. Change it once and done. Buying piece by piece is more expensive.
These are not hard to source. Check all the usual suppliers and expect to pay ~$150 USD.
Old May 26, 2014 | 08:32 AM
larueb's Avatar
I agree with Jag #4. I tied to repair the weeping leak at the sensor site and it was a waste of time. I replaced mine 18 mo ago with a new one and I am glad I did.
LaRue
Old May 26, 2014 | 12:14 PM
scm's Avatar
scm
When I had my 2001 XK8 fixed, my mechanic's comment was "I've just bought the most expensive expansion tank in the world".
Old May 26, 2014 | 11:38 PM
tony bosco's Avatar
Default exp.tank
thanks jag#4 think the tank is next.. see on ebay for around 137.00 from british parts place
Old May 26, 2014 | 11:42 PM
tony bosco's Avatar
Default exp.tank
LaRue
think you and jag#4 are right ..... thanks gona order one tomorrow...
Old May 26, 2014 | 11:45 PM
tony bosco's Avatar
Default exp.tank
thanks.... just hope i can do it right the first time and it works...hate looking at that coolant light.... will order tomorrow
Old May 27, 2014 | 02:41 AM
Keep the "new" Coolant Level Sensor from your old Expansion Tank as a spare - they do fail more often than the Tanks.
Old May 27, 2014 | 08:54 AM
tony bosco's Avatar
Cool
will do GGG... jaguar has exp.tanks for 160.00 with tax think i should go to them or by on line for 137.00............. would it be better to go to jag for the few extra dollars...... are there parts better or the same ???
Old May 27, 2014 | 10:04 AM
Paul Pavlik's Avatar
AFAIK, there are no aftermarket suppliers for the tank. They are all from the same manufacturer.
Old May 27, 2014 | 11:01 AM
Fulton's Avatar
Don't forget the forum sponsors
SNG Barratt - The Ultimate Jaguar Parts Specialist
Jaguar EXPANSION TANK COOLANT RESERVOIR - MJD4400AB
I've used both of these guys, superb service, and both give a discount for members of the forum.
Old May 27, 2014 | 11:19 AM
Bowmanconsult's Avatar
Several on Ebay starting at $138.00
Old May 27, 2014 | 11:39 AM
SNG Barratt USA's Avatar
Former Sponsor
Usually in stock at around $112.40 with your discount.
Come with the sensor LNA5740AB
Please let me know if you need nay further info.
Old May 27, 2014 | 11:40 AM
tony bosco's Avatar
Cool exp.tank
thanks, i went with jagbits (gary) shipping today should have in about 3 days...........let ya know what happens when i install it............
Old May 27, 2014 | 11:46 AM
tony bosco's Avatar
Cool exp.tank
thanks, i went with jagbits (gary) shipping today should have in about 3 days...........let ya know what happens when i install it...jagbits & sng were around the same price, i mentioned the forum too.. paid $144.89
Old May 28, 2014 | 11:39 AM
renaultvation's Avatar
Word of advice when fitting the new tank: Be very careful when disconnecting the pipe from the tank to the thermostat housing. The plastic section becomes very brittle and is likely to break if you flex it when removing the pipe from the tank. Either be very gentle, or be prepared with a length of replacement hose (most people replace the hose with ordinary coolant hose from any motor factor rather than the original plastic/rubber combination hose).
Good luck.
Old May 29, 2014 | 04:49 PM
jsulliva's Avatar
What about the Jaguar Hose Clamps? My Jaguar XK8 has some odd clamps that I have never seen before. About 1/2 inch (12 mm) wide with a portion that is folded back and forth several times. I don't want to mess with them without understanding how they work. How do you remove them? Can they be reused?
Thanks, John
Old May 29, 2014 | 06:07 PM
Gus's Avatar
Gus
Yes the clamp can be reused. As for removing the clamp they can at times be a little difficult because of positioning. Much easier with the proper tool but can be done with dads old pliers.
Tool Link Sears.com
Why are you replacing the tank? Is it leaking?
Old May 30, 2014 | 10:37 AM
jsulliva's Avatar
Gus, Thanks for that information. I still don't see how it all works and I have never seen a tool like that. I will start another thread for my problem regarding a coolant leak.
John
Old May 30, 2014 | 05:06 PM
tony bosco's Avatar
Cool coolant tank replaced--- yaaaaa
hi forum , today i did my coolant tank and it was pretty much of a breeze. took my time ( 1/2 hr. to 45 min.) and my light is finally out. just hope it stays that way............... thanks to everybody for their advice........ tony
