Cooling / Fan temperature points
Old Jun 10, 2021 | 09:12 AM
zray's Avatar
Default Cooling / Fan temperature points
For the few newer members that haven’t seen the wonderful resource of jag repair.com , here is sample of the kind of treasures one can access there. And just in time for summer driving :
These numbers are relevant to the 4.0 engines. Don’t know if they apply to the 4.2’s etc.
I was wondering, and worrying, about my radiator fans. Whether they were turning on and the right times, or running after shutdown properly, etc. This document explains the conditions when they cycle on and off. And under what conditions they will activate when the engine is shut off, and for how long as well.
the Autool X60 is a great product for monitoring the coolant temp, as well as many other engine data points. Amazon has them.
I also just discovered the necessity of cleaning between the A/T cooler and the radiator. The gap between the two is perfect for storing tumble weeds, mummified bugs and dirt in general. A quick remove of the plastic cover that covers the radiator / A/T cooler and the whole grimy collection is revealed. All of the offending garbage was super easy to flush out with a garden hose equipped with a variable nozzle
My only other summertime tip would be to mention the WaterWetter product. Countless times I’ve seen it reduce coolant temperatures by 5 to 15 degrees. May not sound like much, but it could
be the difference between smooth sailing and overheating.
Z
Old Jun 17, 2021 | 04:57 PM
san_arthur's Avatar
Originally Posted by zray
Z
Hi Z. I looked in jagrepair.com but can't find the this information, could you please send right tag?
Old Jun 17, 2021 | 09:03 PM
zray's Avatar
I actually found that attachment when searching in this forum, something along the lines of “radiator fan temperature” or something about the subject of coolant temperature. Since jag repair dot com was the header I’m assuming that was the intermediate source for the information, which looks like it came from the shop manual originally.
Z
Old Jun 18, 2021 | 12:03 AM
zray's Avatar
found it
http://www.jagrepair.com/images/Trai...ual-9-5-01.pdf
section 11.4 Page 118 (of 264 pages)
I found it via post by WhiteXKR, post #33 :
https://www.jaguarforums.com/forum/x...-138312/page2/
Z
Old Jun 18, 2021 | 05:25 PM
san_arthur's Avatar
mmac867
Oct 24, 2019 08:25 PM
mmac867
Jul 13, 2019 10:11 AM
v1rok
Sep 9, 2018 08:59 PM
1100me
Sep 7, 2015 06:26 AM
BlackJack
Feb 11, 2010 06:23 PM
