Correct Nav DVD for 2006 XKR
Old Feb 27, 2014 | 10:41 PM
Moseleykmc's Avatar
Default Correct Nav DVD for 2006 XKR
I am under the impression that only two Alpine DVDs will operate my 2006 XKR system- the early BM9JU91E and the later BM9JG91F.
Am I correct, and is the JG91F version significantly more desirable?
Thanks,
Moseley
Old Feb 27, 2014 | 11:20 PM
01Silverstone's Avatar
Hi Mosely,
I have an 05 XK8, which I presume has the later BM9JG91F disc. Although I've personally never used the older version, it would make sense to me that the newer version would contain more updated maps/POI data and therefore would be more desirable. That being said, I no longer use mine as I've changed out my head unit thereby rendering my nav inoperable. If you're looking to purchase a disc, feel free to PM me.
Old Mar 2, 2014 | 11:42 AM
rjbaldwin51's Avatar
Default Nav System
I have a 06 XKR with the Alpine system. The newest disk is a 2005 version produced by NAVTEK. I have searched high and wide for over a year and there is not a newer disk available. Jag has since moved to a 2 disk system. The only solution I have found is to replace the system with a Garmin, which is upgradable from the internet, and I am in the process of doing that, thanks to this forum.
Go Luck
Old May 14, 2015 | 09:34 PM
jeffatoms's Avatar
Originally Posted by 01Silverstone
Hi Mosely,
Any chance you still have the disk looking for one for my 2001 xkr Thanks Jeff
1100me
Jul 24, 2023 06:10 PM
Doug
Feb 27, 2019 01:31 AM
SeanU
Sep 13, 2015 02:45 PM
tberg
Sep 7, 2015 07:32 AM
Mike Green
Sep 7, 2015 12:39 AM
