Crank pulley removal
Old Mar 25, 2014 | 05:22 PM
mctb's Avatar
Default Crank pulley removal
Just about to do the timing chains and tensioners on my 1997 xk8, I don't have a crank pulley removal tool and don't really want to payout £140 for one any other ideas how to get the pulley off
Old Mar 26, 2014 | 07:56 AM
batroute's Avatar
Machine mart sell a universal harmonic balancer removal kit for about £20 - well worth it- just check it contains the right size bolts for the jag.
Old Mar 26, 2014 | 11:52 AM
mctb's Avatar
That's great I'll get one of them any ideas about undoing the bolt
Old Mar 26, 2014 | 01:50 PM
batroute's Avatar
Smile
You can lock a breaker bar against something solid and use the starter motor to break the nut free.
Another way is to raise the car on a jack, lock the breaker bar on the floor and lower the car suddenly.
If you use either of these "unapproved " methods be very careful - the potential for personal injury is high unless you know what you're doing.
Alternatively you can wrap a strap wrench around the balancer and use the breaker bar in the opposite direction.
The best way, if you have one, is an air driven impact wrench - by far the safest and most convenient - it's the old story, the right tools make any job much easier. Good luck and be safe.
Old Mar 26, 2014 | 03:44 PM
mctb's Avatar
Thanks for that I have a 240v impact wrench which I use for hard bolts looks like I'll get access when I get the rad off
mrplow58
Jan 21, 2024 05:53 AM
Johncy2000
Dec 22, 2017 04:32 PM
auburn2
Dec 29, 2015 06:31 AM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
