Crankshaft Pulley - How should it feel?
Old May 25, 2015 | 08:57 AM
Johnken's Avatar
Default Crankshaft Pulley - How should it feel?
Thanks for looking. Yesterday I posted a thread about my car overheating and trying to determine if the belt was the cause. As per your excellent advice I removed the belt and turned each pulley by hand.
Something just occurred to me, I should have asked yesterday. The crankshaft pulley is not what I expected. It can be turned freely with no resistance and there is a spring feel to it in that it can be moved backwards towards the engine block a small amount against what feels like spring tension.
I wanted to check and verify that this is normal.
Thanks,
John
Old May 25, 2015 | 09:55 AM
WhiteXKR's Avatar
This is not normal. It sounds as if your crankshaft pulley broke loose. See this post on the issue: https://www.jaguarforums.com/forum/x...-remove-89379/ by Walt (may he RIP).
Old May 25, 2015 | 10:27 AM
Johnken's Avatar
Thanks for the quick reply. Looks like I'll have to find a mechanic.
jimforrest (uk)
Feb 28, 2019 06:42 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
Delta66
Oct 4, 2015 05:40 PM
inactualis
Oct 2, 2015 11:13 AM
