Cruise control
Old Nov 23, 2021 | 02:20 PM
drk1074's Avatar
Default Cruise control
When I take a trip, my cruise control works perfectly for 1 1/2 to 2 hours, then it just quits, including the little red light on the cruise button going out. Any suggestions/ideas on why this occurs? 97 XK8 convertible, LHD, 4.0 non-supercharged. Thanks.
Old Nov 23, 2021 | 02:47 PM
fmertz's Avatar
On the early car, the cruise control is vacuum-based, I believe. I'd say double check the vacuum line to that big actuator by the throttle body. Folks periodically find that line popped or otherwise not in compliance with the design. I believe there is a T fitting which means you need to check all the lines involved. Of course, with time, you might want to just replace it.
Separately, you might want to check the actuator itself for leaks. Apply some vacuum and see if it holds a while.
Best of luck, keep us posted.
Old Nov 23, 2021 | 03:30 PM
drk1074's Avatar
Thanks. I’ll check that out.
66RBS
Nov 21, 2021 08:39 PM
Lalub
Jul 12, 2012 11:00 AM
Davexjrv8
Nov 29, 2011 09:38 AM
JagWatcher
Dec 2, 2007 12:32 AM
