Cylinder heads gaskets bolts
Old Apr 2, 2011 | 03:57 PM
DISCOSTU29's Avatar
Default Cylinder heads gaskets bolts
I know its good practice to change the head bolts when you do the head gaskets but do you have to change them? I am on a tight budget and when i add £150 for head bolts, £80 for spark plugs, £230 for a gasket/seal kit and approx £300-400 for skimmng, cleaning and lapping valves and £250 for tensioner set (mines are cracked) it turns into an expensive job.
Old Apr 2, 2011 | 04:05 PM
plums's Avatar
80GBP for plugs? That's really steep.
The machine work seems kind of steep too. Especially if you really mean valve lapping.
Anyways, the TSB's say on warranty work, head bolts may be used twice. When a mechanic reuses them, he is supposed to mark them on the head with a punch mark.
If the plugs are ok, maybe you can get by on them for a while.
Old Apr 2, 2011 | 04:54 PM
DISCOSTU29's Avatar
Yeah I thought it was steep too, £60-100 for plugs on ebay. Valve lapping is what i mean, they do a compression test on the heads to see if the heads are cracked or if the valves leak, then they disassemble, chemical dip, skim, lap and reassemble. They do a good job but it can be costly if they find any problems.
Old Apr 2, 2011 | 10:19 PM
motorcarman's Avatar
The reuse twice TSB is for the AJ6/AJ16 6 cylinder engine ONLY. That engine also has the reuse Main Cap bolts twice.
Here are the TSBs
bob gauff
File Type: pdf
File Type: pdf
Old Apr 2, 2011 | 10:30 PM
XKRacer's Avatar
You can re-use the head bolts, the £3-400 for the head skim and relap is not what I would call out of the way and £10 a plug is the going rate for Iridium plugs.
Something you don't mention is if it is a 4.0 or 4.2, if it is a 4.0 fit 4.2 metal head gaskets, they are much better and rarely let go, unlike the 4.0 composite type.
Old Apr 2, 2011 | 10:36 PM
plums's Avatar
Glad you came along
aholbro1
Dec 29, 2024 06:46 PM
vicom
Sep 17, 2015 03:32 AM
bavareze
Sep 11, 2015 01:49 AM
joesoap
Sep 10, 2015 01:09 AM
1964Daimler
Sep 9, 2015 11:20 AM
