Diagnostic help request - link to issue - I may have been ripped off
Old Jul 15, 2018 | 08:48 PM
scottatl's Avatar
Default Diagnostic help request - link to issue - I may have been ripped off
I have been having trouble starting the car for a few months. My mechanic told me last time it was the fuel pump, which made sense. He thought the return valve was busted so I had to crank the pump for a bit to get the fuel to the injectors. Last week my car would not start he told me it was the fuel pump. I paid my $700 bucks. They also charged $200 for additional trouble shooting, they said the engine was flooded and they had to poor some transmission fluid in the valves to clear it up. This is odd, if the fuel pump was bad how could the engine be flooded. Now the bad part is the car starts but still has the same problem.
Now they are saying it may be a bad Fuel Injectors that is creating the hard start, is that reasonable given the issue? I feel like I am getting the run around.
I have included a link to what the car sounds like when I try to start it.
Any ideas?????
Old Jul 16, 2018 | 12:25 AM
baxtor's Avatar
I can't speculate on the diagnosis but bore wash was a problem for these cars at least for a time. I think that may legitimise the transmission fluid thing.
Old Jul 16, 2018 | 01:12 AM
woox4's Avatar
What codes is it giving?
Old Jul 16, 2018 | 01:20 AM
rothwell's Avatar
Okay so it has been a problem for a few months
and replacing the fuel pump did not help
and in the video it appears that no engine warnings are shown
what is mileage?
has engine ever overheated?
does it only happen when cold (or hot)?
how long does it have to sit before the problem reoccurs?
how does it run once started? rough? smooth after short time?
can you accelerate normally or is that a problem too?
Starting with simplest thing first, did they try replacing the fuel filter?
Old Jul 16, 2018 | 02:26 AM
scottatl's Avatar
what is mileage? 90k
has engine ever overheated? no, never has
does it only happen when cold (or hot)? If it sits for say more than 5 minutes it happens, the engine can be warm or cold
how does it run once started? rough? smooth after short time? runs fine after it starts
can you accelerate normally or is that a problem too? it accelerates fine
Thanks!
Old Jul 16, 2018 | 02:49 AM
Is this a COLD start issue only or does it affect both COLD and HOT starting?
If it is regardless of engine temperature, I would start investigating fuel delivery - sufficient fuel pressure at the injector rail which can be checked by depressing the schrader valve. Inadequate pressure shouldn't be the new pump but could be restricted fuel filter or fuel pipe.
If it is only a COLD start issue then low cylinder compression could be a cause. However, if it is nothing mechanical, the ECT (Engine Coolant Temperature) sensor is a suspect.
Old Jul 16, 2018 | 02:53 AM
I took a long time after reading your first post to finish and post my reply in #6 by which time you had already answered the COLD or HOT question!
Therefore check compressions and suspect ECT sensor.
Old Jul 20, 2018 | 03:05 PM
Truck Graphics's Avatar
If you still have this problem, check the battery ground at the chassis (trunk/body) side as well as the negative post.
Old Aug 11, 2018 | 01:31 PM
scottatl's Avatar
I have tested everything and it is all fine. I really think the place I went to did not replace my fuel pump but said they did. Is there a way to test if my issue is the fuel pump. From my understanding, if the fuel pump has a broken valve and the fuel is receding back into the tank that would create my issue. How can I prove to myself that it is or is not the fuel pump.
The fact that lead me to believe this:
1. happens hot or cold
2. does not happen if the engine is only shut off for a minute (possible that the gas has not receded yet)
3. They did a smoke test (at least they say they did) and no air leaks
I just don't know what else would create my issue with the above facts......
Old Aug 11, 2018 | 02:38 PM
motorcarman's Avatar
Just install a fuel pressure gauge on the fuel rail and watch the pressure??
If the pressure drops fast, the rail could develop a 'vapor-lock'.
Pressure drop could be a faulty fuel pump check valve, pressure regulator or 'dribbly' injector(s).
Also check the vacuum line to the FPR to see if the diaphragm leaks fuel.
bob
Old Aug 11, 2018 | 03:11 PM
scottatl's Avatar
thanks, i will give it a try
Old Aug 11, 2018 | 03:40 PM
RJ237's Avatar
Not sure exactly where you live, but Enzo's is in Marietta near the air base and they have a good reputation, Jag experts for many years.
Enzo's Automotive Service – Atlanta Jaguar, Land Rover, Ferrari, & Maserati Repair and Service
Old Aug 11, 2018 | 04:04 PM
L Leon Brewton's Avatar
Uhm, wonder which valves the mechanic is referring, and I hope that they drained some of engine oil prior to adding the trans fluid. So, what color is the oil now?
Also, I used sea foam by pouring it directly into my evaporator line and I drove it few miles, then the next day I added some to a full tank of gas and wallah!, so as long as you know that your 0xygen/fuel mixture needs a touch-up and injectors and combustion chambers need gargling.
If the battery check, cranking/starting amps, charging, pressure and compression checks does or does not reveal anything, try adding sea foam or sea glass to your evaporator line/ or intake and later to a full tank of gas as prescribed by manufactures direction.
https://seafoamsales.com/how-to-add-...-diesel-fuels/
Old Aug 11, 2018 | 05:37 PM
Robman25's Avatar
Leon,the ATF went into the cylinders not the sump.
Scott have you tried turning the key to the on position but not ‘start’ then off and repeat for 3-4 times to see if that initiates a quicker fire up? This is one way to check if the non return valve has failed.
Old Aug 11, 2018 | 05:45 PM
Robman25's Avatar
Just watching the sea foam demo. Is it me or does it look like there is more illumination on the after shots? Looks like a good way to burn money to me. And carbon next to the cylinder wall causing friction? Please!
Old Aug 11, 2018 | 07:24 PM
RJ237's Avatar
The fuels in the US and probably most of the world have sufficient detergent additives to keep the injectors clean. It can be helpful for a car that has been stored, but it's mostly snake oil.
Old Aug 12, 2018 | 06:59 AM
Jon89's Avatar
I agree that most fuel additives are a waste of money. But there are a couple of exceptions. Chevron Techron is one of them....
Old Aug 12, 2018 | 09:06 AM
rothwell's Avatar
Old Aug 12, 2018 | 09:12 AM
JimmyL's Avatar
Let us know Scott. I'm really curious now. Fuel pressure regulator ? Fuel pump ? Injectors ? Bore wash ?
EZDriver
Jul 27, 2015 07:23 PM
Sukki
Dec 2, 2013 05:40 AM
LoveItHateIt
Apr 15, 2012 10:41 AM
FLLW owner
May 6, 2008 07:19 PM
jaggirl2008
Jan 11, 2008 08:49 PM
