Diagnostic Trouble Code
Old Oct 3, 2010 | 07:45 PM
npopowitz's Avatar
Default Diagnostic Trouble Code
Hi all,
I have a 2005 XK8 Convertible. I bought a diagnostic computer unit so I could read my own DTR codes and when I plugged it in, I got a code of "P1111" which apparently means "Manufacturer Controlled Fuel and Air Metering." I have no idea what, if any, problem this could be referring to. The car is running fine and there are no warning lights on the dash. Any ideas? Should I be concerned?
Any and all input is appreciated. Thanks.
Old Oct 3, 2010 | 08:06 PM
Gus's Avatar
Gus
This will help you. http://www.gusglikas.com/AutoRepairElectrical.htm
Old Oct 3, 2010 | 08:33 PM
steve11's Avatar
ud
P1111 is not a fault code. It is a diagnostic system readiness code produced after any faults have been repaired and cleared, along with any related drive cycles completed. P1111 is not eraseable and doesn't need to be.
One last point, you cannot use generic P-1xxx Codes for Jaguar. Any P-1xxx code is manufacturer (Jaguar) specific and most generic P-1xxx codes will not be defined the way Jaguar has assigned them.
Old Oct 5, 2010 | 11:50 AM
npopowitz's Avatar
Thanks Guys, I guessed that it might be a readiness code, but when I got the "Manufacturer Controlled Fuel and Air Metering" message I was confused. Interesting what Steve says about the non-specific codes, the meter manufacturer website required I input my make, model, year and other info before providing the message, which then made no sense to me. Anyway, I appreciate the help and the quick response.
Jpav27
Jul 31, 2022 06:43 AM
philwarner
25
Jun 26, 2021 05:43 AM
Dixie61
Sep 19, 2015 06:29 AM
tsimms7
Sep 15, 2015 12:43 PM
jagfool
Sep 14, 2015 07:50 PM
