A Different Tilt Motor Solution
Old May 2, 2016 | 11:10 AM
  #41
mc_jag's Avatar
Well, I don't doubt that your solution works. I just wanna know if a replacement of the BPM helps too ;-)
Originally Posted by astromorg
Sorry, but I don't know of any evidence that would persuade me to pursue that option, especially as my current no-cost vasectomy solution continues to provide 100% reliability!
Old Jun 3, 2018 | 01:40 PM
  #42
risktkr's Avatar
Smile 1995 xj6 this fixed my steering wheel issue
Cutting the blue / white wire solved my issue in a second. Thank you thank you thank you!! No issues afterward!!
A DIFFERENT TILT MOTOR SOLUTION
Attached is the full account of the investigation I did to arrive eventually at this solution to the well-known problem with the steering column tilt motor and its tendency to move only in small downward jumps from the fully raised position. For those wishing to skip that detailed story, here’s the vital bits!
As sometimes happens in researching the causes of this sort of problem, discovering the final simplicity of the proposed alteration had an element of luck. Furthermore, quite how and why the BPM allows the change to work remains an enigma to me, but I have run my XK8 with it for some weeks and miles to give me the confidence to stay with it. If any electronics experts can explain what is happening, or if there are any drawbacks unforeseen by me, I’d be pleased and grateful to hear about them!
But just before I start I’ll give the usual disclaimer as far as anyone else trying out anything I describe here on their own car. You follow my lead at your own risk!
The Fix! All that is required is to disconnect the wire that provides a nominal 5 volt supply from the Body Processor Module to the feedback potentiometer in the tilt motor/gearbox. Nothing more and nothing less. It really is that simple.
The photograph of the tilt motor and its wiring shows the Blue/White wire to disconnect arrowed. I did this by unsoldering it from the circuit, but wire cutters would be quick and easy or removing the wire from the arrowed 6 way White connector on the column is also feasible. As far as I can determine, that wire has always been Blue/White through all the model years.
Of course it’s not possible to prove that a tilt motor with this modification will never revert to its original intermittent stuttering as has often happened with various other proposed changes, but if some brave souls out there would be prepared to give it a try and thereby confirm or deny that my proposal is effective in more than just my XK8, a more definite result, whichever way, would be useful.
Old Jun 10, 2018 | 05:05 PM
  #43
sn1perii's Avatar
Default Snip Snip
thanks for the tip! Works great now!
Old Jun 12, 2018 | 07:58 PM
  #44
VinceCh's Avatar
Add me to the list! After a few years of intermittent operation, the tilt is now working reliably, thanks to your mod.
Vince
Old May 2, 2025 | 03:47 AM
  #45
RaceDiagnostics's Avatar
Better late than never, finally got round to this after 10 years of delay, fantastic quick fix!
Old May 2, 2025 | 07:12 AM
  #46
Jon89's Avatar
Well done. I need to remember to do this the next time I am working on something in the interior. What tools are needed to remove that steering column cover and are there any tricks to doing so?
Old May 2, 2025 | 11:02 AM
  #47
Just two 8mm bolts on the bottom edge to remove for access, no need to remove the panel, just loosen to get in to the blue/white wire and snip. It's a 5 minutes job.
Old May 2, 2025 | 01:07 PM
  #48
Jon89's Avatar
Thanks for the tip. One of these days....
Old Jun 1, 2025 | 02:33 PM
  #49
Zspot's Avatar
Add me to the list of happy white/blue wire snippers!
Seeds kinda went in my belly before the quick cut, but trust the forum.
Steering wheel now goes up and down smoothly and without stopping!
Old Jun 6, 2025 | 04:09 PM
  #50
PASXK8's Avatar
Default Fixed for me too
I finally took the plunge and snipped the wire. It fixed the problem as it has for others. I will monitor and report back if I have any issues. This forum and the XK8 community is great !!
stan61
Sep 28, 2020 03:19 PM
TurboWood
Apr 13, 2020 08:53 PM
Johnken
Jun 17, 2015 05:08 PM
Johnken
Apr 11, 2015 11:59 AM
theJPster
Jan 23, 2012 08:26 PM
