Display backlight out ?
Old Mar 12, 2010 | 09:16 AM
JagJoel's Avatar
Default Display backlight out ?
I have a backlight out on the display in my center console. Its the upper display where the temp and AC settings are shown. The passager side is now dark, the display is still functioning correctly, but just that it is only backlit now on half of the display, the other half is dark.
Question, anyone else have this problem, and if so how do you correct it? Is it simply a light bulb or LED that needs to be replaced, if so how hard is it to get to this. Input appreciated.
Thanks,
Joel
Old Mar 12, 2010 | 12:17 PM
iilium's Avatar
I would appreciate any input as well--I have the same issue only it is the entire temperature display, not just half. Thanks!
Old Mar 12, 2010 | 05:58 PM
H20boy's Avatar
I got the green lights replaced behind the buttons when I was doing my radio, but never looked behind that part of the climate control display panel. If you can get the center console out, you can surely check it yourself...if you're inclined. It isn't that difficult to do that either.
Old Mar 13, 2010 | 07:11 AM
mbalce's Avatar
I had the same issue on my 99 when I first bought it. Half the temp display had no backlight. Took the display out (find radio removal instructions on this forum) and replaced twist in light bulb. Jag wants big $$ for these, my original thought was to replace every bulb since I had it apart figuring they are all 10 plus years old. Think I added it up to over $200 in bulbs though... Replaced the burned out ones (had a button that didnt light up either) and put it back together. All in all, pretty easy. I think you can find the bulbs online a lot cheaper though but I wanted to put it back together and start driving it again...
Note- protect the gear shift plate when pulling the radio. Pretty easy to scratch the black matte finish as you slide the radio out and the wiring harness is still connected. (and you know how I know)
Old May 8, 2010 | 04:13 PM
attaboy's Avatar
Good Thread ... I have one out, right between the speedo and tach. Anybody do that one here?
Old May 8, 2010 | 04:31 PM
Gus's Avatar
Gus
I replaced my bulbs when I installed my I-Pod http://www.gusglikas.com/AutoRepairIpodInstall.htm
Old May 8, 2010 | 04:36 PM
Thomasso's Avatar
My display is unlit. I disassembled and checked the bulbs with an OHM meter, Checked OK. Any other ideas?
Old May 8, 2010 | 05:00 PM
Gus's Avatar
Gus
I reinstalled 2 of them that checked good on the bench with a volt/ohm meter. They are not working! I did clean the contact area prior to the reinstall. I would recommend replacing them all. I have not checked but I was told that you can get the bulbs from Radio Shack a lot cheaper than Jaguar. I think this is it http://www.radioshack.com/product/in...ductId=2062368
I guess it would be good to read the entire post. Are they the only lights that are not working? If all your lights are out I would check the potentiometer located on the left of the steering wheel column. If this is not the case then I would check the wiring oneline for your car. http://www.gusglikas.com/AutoRepairElectrical.htm
Old May 8, 2010 | 05:12 PM
brgjag's Avatar
I have a some out on my radio, and the rear fog light thingy's button red light is out also.
Old May 8, 2010 | 11:58 PM
H20boy's Avatar
That red light in the Fog switch is built in, not easy screw type like the backlight bulbs, I couldn't find any way to get to those w/o a little hack job. Not that I needed to thank goodness.
Old Jun 26, 2010 | 12:08 AM
H20boy's Avatar
brgjag, did you ever fix you red button on your rear fog? My front fog light (not the green backlit) is out. BTW, my rear is amber, my front is (was) red, I bet my buttons got switched at one time!
I'm close to pulling the radio/aux switches out to repair a wire behind my system. This, and the bulb are not critical, just nagging at me (and I'm always looking for a good project) since I can't change my JAG clock using the nav if this wire isn't connected.
I'm learning to solder too...dangerous, I know.
Old Jul 21, 2010 | 11:52 PM
H20boy's Avatar
bump to see if I can get brgjag's attention I'm about to tear this row of light switches out, but only if the indicator light is repairable. No reason to remove the center console and all that trim if I can't. I may just try to source a newer row of buttons.
GGabriel
Nov 22, 2018 03:53 AM
flyingv65
Oct 1, 2015 01:54 AM
al_roethlisberger
Sep 21, 2015 08:15 PM
