Does a Low Oil Pressure warning need to be reset before the car will restart?
Old Jan 13, 2019 | 03:48 PM
reedhatkoff's Avatar
Default Does a Low Oil Pressure warning need to be reset before the car will restart?
2000 Jag XKR
Does a Low Oil Pressure warning fault code need to be reset before the car will restart?
The car displayed the engine fault warning, and the oil was almost 3 quarts down, and failed to start--- even after adding oil.
After the oil was filled, the car still wouldn't restart-- almost a little chug... as if the car were out of fuel (which it was not).
Does the Low Oil Pressure warning turn off the fuel pump?
How does the Low Oil Pressure warning disable the engine from starting, and how can if be reset?
The car is inop in a supermarket parking lot.
Old Jan 13, 2019 | 04:02 PM
frankc's Avatar
I cannot see how being low on oil can stop you starting the car except of course the car is so low on oil the engine has seized.
Try this first. Imagine your facing the same direction of car. Drivers side where you are? Between the door jam and the car body is a sort of D shaped panel. Just pull that off. In there on the right corner you will see what looks like a medium sized tube? On top of that is the cut off switch. Try pushing in the top of that and that will re-set the cut off if its tripped. Will see if I can find a photo for you .
Here you go, this is from a 2005 model but it will give you some idea.
Fues on left. Inertia/cutoff switch on right.
Old Jan 13, 2019 | 09:22 PM
zray's Avatar
I would be wanting to know where the 3 quarts of oil went and how it got out of the engine, i.e, , leaks or past the rings, etc.
How long / how many miles has it been since the oil level was checked ?
best of luck,
Z
Old Jan 14, 2019 | 03:00 AM
The car displayed the engine fault warning, and the oil was almost 3 quarts down, and failed to start--- even after adding oil. .....
Welcome to the forum reedhatkoff,
I'm used to capacities in litres but 3 quarts immediately jumped out as a LOT! The refill capacity is 6.9 quarts so that is dangerously low.
The oil pressure sender simply triggers the warning light - there is no interlock to prevent starting.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 14, 2019 | 07:10 AM
oldmots's Avatar
How far did you drive with oil warning on? The warning light is set about 2 psi, so when it goes off, the engine should be shut down right then, not later. More than 20 seconds and you risk spinning the bearings.
If the oil is really low,the bores could be dry, so try pulling the plugs and putting one teaspoon of oil in each bore, button it up and try again.
dmukic
Oct 26, 2019 10:49 AM
tiouis1964
May 9, 2019 04:12 AM
MWags
Aug 20, 2017 10:27 AM
dx3
Apr 21, 2012 08:32 PM
Mr T
General Tech Help
Feb 20, 2008 07:03 AM
