Door Clip
Old Jul 7, 2014 | 04:50 AM
DevonDavid's Avatar
Default Door Clip
Can anyone help please ................
I have just removed the door card to install WhiteXKR's Remote Hood kit, and have found the usual broken door clip - rear top. In fact, the whole of the interior of the door is a mess, so I assume that at some time in the past, the card has been removed to (probably) bash out a dent from the inside, and whoever did the job has not been too careful with reassembly.
The clip - C2N 3836, is no longer available from Jaguar so I am going to try and rebuild the old one. Unfortunately, the broken bits are not lying in the bottom of the door so I can't use them to get the dimensions.
Could someone with a spare bracket (or door card) take the trouble to measure the distance between the base and the top for me please - I think I could then make an alumin(i)um bracket to replace the missing bit. Also, a photograph of an unbroken one would be very helpful. Right Hand Side (UK Driver's side).
Thanks in anticipation ...........
Cheers,
David.
Old Jul 7, 2014 | 05:30 AM
Taffrican's Avatar
Default Broken Door Clip
DevonDavid,
I have a brand new spare clip.
If you PM me your address, I will post it to you.
Regards: Taffrican. (South Wales U.K.).
Old Jul 7, 2014 | 07:21 AM
Originally Posted by Taffrican
....... I have a brand new spare clip. If you PM me your address, I will post it to you. .......
A generous offer.
Old Jul 7, 2014 | 09:29 AM
DevonDavid's Avatar
Taffrican.
Have sent PM. That's an extremely generous offer - sincere thanks.
David.
Lawrence
XJ40 ( XJ81 )
May 9, 2023 06:31 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
sadepol01
Sep 11, 2015 05:26 AM
