Door handle linkage disconnected
Old Mar 27, 2021 | 05:30 PM
alanroberts50's Avatar
Default Door handle linkage disconnected
Hi when I purchased the vehicle about 8yrs ago the passenger exterior door handle was disconnected while the interior door handle
worked just fine. Some how I recall a temporary fix that included some glue but don’t remember anything else.
I am attempting to do a proper fix this time but could use some guidance. So far I have the interior door card off and can see a metal linkage rod hanging straight down with an “eye” on the end that looks like it would attach to the back of the door locking mechanism. Should I be removing the 3 torx screws that hold the lock in place and will nuts fall off inside the door if I do that? Also what should be locking the “eye” on the end of that linkage rod to the door lock mechanism?
Hopefully there is a pic attached. Just didn’t want to proceed at this point without advice, thanks for any guidance provided.
Old Mar 28, 2021 | 11:46 AM
Default Anyone know the answer?
Hi the pic shows the disconnected linkage from the door handle. I searched the parts list and JTIS but nothing seems to show how this attaches to the lock. Does anyone know? Does it just push on or is there a screw to hold it in place? Any parts numbers would be much appreciated...
thanks
Old Mar 28, 2021 | 01:11 PM
So I pushed the linkage onto the lock pin (see pic) but don’t see what will hold it in place is it a circlip or nut or what?
thanks
Old Mar 28, 2021 | 04:21 PM
Dr. D's Avatar
The plastic Door Lock Linkage Clip on the tip of the fingertip in your photo appears to be part # GNA1122DA available on Ebay for $5.99 / free shipping. To my knowledge, it just snaps around its mating metal ball. I think that both the door latch and the exterior door handle assembly are threaded to receive their mounting screws. I am going from my memory of replacing my door handle gaskets a few years ago. Wish I could help more, but hopefully, someone more knowledgeable than I will respond. Good luck.
Old Mar 28, 2021 | 05:13 PM
The ball in the black plastic section at the end of the rod (arrowed blue in the diagram) should be part of the door latch.
Looks like it's broken off.
Old Mar 28, 2021 | 06:50 PM
Thanks so much. I finally found a pic of the part number you mentioned. I will try and replace the black plastic part. The “ball” is on the lock itself and my black plastic part just pushes on but won’t stay in place so hopefully the new part will be more of a snap on fit. Will let you know once I get the part installed.
Old Jul 9, 2022 | 12:28 PM
JayJagJay's Avatar
Hello Gus and Good Doctor...Folks
I was just inside my driver's door messing around with the linkage for the exterior door/key lock where it connects to the lock assembly. The key hadn't worked since getting the car. This is that PROJECT car the took the swim in the flooded lake, or whatever the story is.
It seems the plastic tangs have broken off at that last plastic section of the link arm (green arrow) where it clips into the hole on the assembly... It won't/can't stay attached. Are there any part numbers available or a solution anyone has come up with as a fix for this?
As important... What is the process for setting the correct position of the arm once the clip and arm are connected??? Is it in the MIDDLE at rest? Somewhere between lock and unlock when turning the key from outside? I could see and hear the clicks of a micro switch when the arm is in the top most position (when the key is turned to locked on one extreme),,, but am confused about what triggers the action (windows and top down) when turning the key in the unlocked position and where the arm on the assembly is supposed to be at rest. Actually,,, the whole thing was making me NUTTS and I just packed it in for the day.
Any guidance is greatly appreciated!
Old Jul 9, 2022 | 04:40 PM
Gus's Avatar
Gus
The plastic thing (green arrow) I think is available at jagbits. As for the switches and the drop of the windows several switches in that door latch control the window drop. As best I can tell several switches in the latch must work in unison resulting in a signal to the security module to operate the window.
Old Jul 9, 2022 | 08:48 PM
JayJagJay's Avatar
Hey Man, Thanks for responding.
The little plastic bit I'm looking for (see photo) is the one at the end of the arm that is attached above to the key lock/barrel in the exterior door handle... I may be mistaken but when I was going back and forth with a guy JLClassic I understood him to say that the steel ROD is available,,, but the plastic end section is not...? That they are 2 separate parts? I thought that strange and will write back to them.
Basically, all the switches in the assembly are working (I replaced one 2yrs ago) and I can temporarily get the key in the lock to lower all windows and top, and then close all up again, set the alarm, but the clip won't stay in the little hole on the arm attached to the entire assembly. PITA. It falls out.
Also, when in the inactive position, where (when the plastic clip is holding temporarily) the arm attached to the assembly is at rest,,, setting it in exactly the right spot is proving difficult. I'm wondering if anyone has found and knows how to find that sweet spot.
It's amazing how much little things can throw so much off. I fear, for whatever reason, locking up the car, even if I accidentally forget and leave an interior light one day, and at that I will be locked OUT of the car because the door lock doesn't function... Anyways.
Back to creating an air gap on the ignition amps in the XJS... Goes on and on and on and on, lol
Old Jul 10, 2022 | 02:10 AM
Pistnbroke's Avatar
Having taken these door locks off many times I find unless you have very strong hands pushing the black part over the ball is almost impossible.
I take a block of foam about 3 incuble and push it into the upper area then position the black bit onto the ball. The foam holds it in place . Then I take a 3 ft crowbar and place it just above the ball on the black bit and push hard and it goes on
Old Jul 10, 2022 | 08:38 AM
JayJagJay's Avatar
Same here. That black ball to clip (the black one) can be tough.
Any leads on sourcing the OTHER clip? The adjustable white plastic push clip (see photos) for the exterior key door lock link... If I order one from JLC (or some other), do you think it will be the entire thing, or just the metal rod section? I spoke with JLC and they say it's just the metal rod...? Which don't sound right.
Old Oct 26, 2022 | 02:26 PM
Josh-XK60's Avatar
Sorry to bump such an old thread, but does anybody know the specs for the T25 screw the blue arrow points to?
This screw is missing from one of my doors and would appreciate if somebody knew the screw specs before I take it out of the other door to check haha
Old Oct 26, 2022 | 06:01 PM
JayJagJay's Avatar
When you say screw and blue arrow, do you mean the rod?
If rod,,, I would suggest digging around in the void at the bottom of the door cavity. All kinds of treasure can be found down in there.
And, by the way, a member SHIPPED me the little section I was looking for in this thread. Worked a treat and my door lock now works, and even controlled the hood, with key turn. Took a little fiddling to get it just right, but it WORKED!
Old Oct 27, 2022 | 04:28 AM
Josh-XK60's Avatar
I replied to the wrong thread somehow but thanks for your input!
jomo
May 7, 2016 09:28 AM
SteveSheldon
Feb 23, 2014 10:03 PM
PhilB
Jul 10, 2013 07:50 PM
sidescrollin
Apr 7, 2013 05:04 PM
teflondon
Jul 8, 2009 07:25 PM
