door locks II
Old Jan 20, 2018 | 08:49 AM
MEM109's Avatar
Default door locks II
weirder and weirder
P door doesnt lock with key (old post) Did hard reset and now when I lock d door with key the alarm goes off unless I physically lock p door from inside.
Also found blown fuse(#2 d locking actuators) no change with new fuse. I also now have the d door lock cycling lock/unlock when put in gear , Does any of this make sense to anyone?
MEM
Old Jan 20, 2018 | 09:13 AM
graham11's Avatar
I had the exact same problem to yours,installed new passenger door micro switch problem solved 👍
Old Jan 20, 2018 | 10:08 AM
Micro switches. Jaguar P/N C2N1908 but available from other sources at lower cost.
Old Jan 22, 2018 | 05:57 AM
MEM109's Avatar
Copy that, micro switch was t to check, I assume it is inside the door panel?
thanks MEM
Old Jan 22, 2018 | 08:03 AM
graham11's Avatar
Yes,go to the sticky how to videos number 4 (door latch removal and replacement )this will give you a good idea of what to do.
Old Jan 22, 2018 | 08:40 AM
Check my post on disconnecting the Door Latch link. There's an error in Reverend Sam's video which is how he broke the link.
altownsend
Jan 20, 2018 10:43 AM
XJ 4Ever
Aug 29, 2017 03:23 PM
yourtireman
Jan 12, 2009 08:57 PM
justatoy
Nov 8, 2007 11:40 AM
